Base Looking for recommendations for a tree mounted antenna
This may be really redneck, but it worked. I hired a tree trimmer with climb rig- that cost 100.00. I had him climb as high as he could in a pine tree, big blue spruce, so he was up about 30 feet. Screwed a 2X10 piece into the tree. Then he mounted my A99 to the 2X10, and secured everything to the tree with ratchet cargo tie down straps. I looked neat, because the tree hid most of the A99- The top section was partly visible. I was very pleased. I had less than 1.3 SWR on a 40 with the tree rig. Hope the Idea helps someone. Redneck A99 tree rig.
(J) Bonding of Electrodes. If a ground rod is installed to serve as the grounding electrode for the radio and television equipment, it must be bonded to the building’s power grounding electrode system with a minimum 6 AWG conductor. } See Figure 810–16
  • bonding.pdf
The tree is within the 150 ft of the zone of protection
The gear is using the house ground rod, and the coax feed will be grounded at the entry point to the house and connected to the house ground.
The antenna is grounded with it's own ground rod at the base of the tree.
Reactions: Redbeard U812
Guys around here are suspending Antron 99 antennas in trees...kind of like how one would raise a dipole. No climbing involved.
Could only get a vague description on how it was being done. Finally, I got schooled on how to do it. They are using two ropes. Attach one rope about 3/4 the way up the antenna. He said he ties a rope to the antenna, and then secures it with 200 mph duct tape.
Install a mast clamp or screw clamp on the bottom of the antenna, and tie a rope to it. Pull the antenna up via the top rope, and then secure the rope on the ground. Then use the rope on the bottom to adjust the antenna vertical. Then secure the bottom rope to the ground.
Can let the antenna down to change duct tape, check coax, and etc. when ever you need to. Hardest part for me is getting the rope around the limb I choose to suspend it from.
You had me until the word duct tape.
