Skipper 300 blown
Van Lifeson
Well-Known Member
Aug 11, 2018
227
266
Was talking on a skipper 300 the other night when all of a sudden I heard a loud clunk. Amplifier has no output. I think the transformer may have blew a winding? What do you all think? Thank you
I have 260 volts out of the transformer. The schematic says 350 I believe. Is this ok?
No. The schematic shows 700 Vdc after being rectified and filtered.
Since this amp uses a half-wave doubler rectifier, that would work out roughly from 260Vac from one secondary to 728Vdc. (260*2.8RMS=728)
Check rectifiers and filter capacitors.
David
P.S.
Schematic based on 117Vac input.
And why do people who could work sit around and collect welfare that I pay for?
One of the many age old questions lol.
If the two large filter capacitors are original, they should have been replaced decades ago. They weren't meant to last 20 years, let alone 40-plus.
The 'clunk' suggests that the rectifier diodes experienced a significant current surge before the fuse tripped. We always replace the rectifiers along with the filter caps. The old ones might be good. A shorted rectifier can pop your shiny new filter caps in the blink of an eye.
We adopted the policy of ALWAYS replacing rectifier diodes along with the filter caps. Cheap insurance. Cheaper than that second pair of filter caps when the first pair gets assassinated by a damaged rectifier diode.
Reactions: Tokin and Dmans
  • @ Spanish:
    Where do i upload schematics
