****************Updated 13.8V 100A PS recommendation***************
Get a HSTNS-PD11; 438202-002; 440785-001; 441830-001; DPS-1200FB A
If you want a turnkey solution with on/off switch and voltage meter, then get one of these: https://www.parallelminer.com/produ...pter-compatible-with-hp-1200-watt-dps-1200fb/
If you want to manually control it, put a 22K resistor between 36 & 37 and an on/off switch between 33 & 30 (jumper the two if you are going to control the AC power). If you want to add an amp meter use pin 34 - 60.15mv/amp.
Then watch this video for the Voltage adj. and OVP adj. mods:
For voltage adjust, turn pot CCW to increase voltage. If you need a higher OVP than 14.2v, use a lower value resistor. For example, a 82K resistor = OVP @ 14.45v.
Youre right, i read the small print wrong. It read IF out of stock, all i saw was the out of stock part lol. Thanks for the correction.It says 193 available?
4 would be nice but 6 gives me good redundancy in case of a failure of one or more units. Id like my supply bank to show me if a unit fails and what unit(s) failed.I just wanted to confirm that the breakout board will work with this:
https://www.enterasource.com/hp-438203-001-1200w-common-slot-silver-hot-plug-ac-power-supply
It isn't listed exactly, but will work on a similar model. I want to buy four of these and just want to make double sure that I am getting the right stuff.
Thanks
Chris
Id like to run 6 of these 100a hp's in parallel.
Id like to string 4 of the 2400 watt units in parallel. I believe that would be with 240 ac input 640 amps at 15 volts output. That's what I want.
Are you making a welder? My 750a stick welder really runs the electric bill up when I get on a big project. I have it on a 50a breaker using a clothes dryer receptacle to plug in to.Id like to string 4 of the 2400 watt units in parallel. I believe that would be with 240 ac input 640 amps at 15 volts output. That's what I want.
The more i cruise this site the more i like it lol.
Im tired of upgrading and winding up with a pile of supplys. I have 4 now lol. If i can build one supply that will do whatever i need and then some for a fraction of a shop built smaller unit im all about it. I can get what i need to make 600 amps for around $700 it looks like. I just need to find out if the voltage is adjustable on those units and if they can be ran in parallel.Are you making a welder? My 750a stick welder really runs the electric bill up when I get on a big project. I have it on a 50a breaker using a clothes dryer receptacle to plug in to.
I used to use my dryer circuit for my shop (including welder). Then I replaced my electric range with a gas range that uses battery ignition and doesn't even have an electrical connection, which freed up a 40 amp circuit.Man I've been there. A friend runs an electrical company and they've been slow because of the China Virus pandemic. I paid one of his guys to install a sub panel in the garage. I feel like a king being able to weld and dry clothes at the same time.
