Solar Prediction
solarn0nbh.php
Reactions: Rwb
Whats' been seen...
Yet...
Green Dot - Expected by Averages
Blue Dot - Prediction by Magnetic 22-Year Cycle "Hilbert Transform"
Hard to call - worse than this years Elections...
Eyes to the Skies...​
Partial reasoning for this disparity, an article in which these are discussed, can be found here...
https://link.springer.com/article/10.1007/s11207-020-01723-y/
If you take a look at the 11-year cycles, then combine with a 22-year cycle - based upon Magnetic interactions from the termination of one 11-year cycle into another - then observing a second type of pattern using 22-year Cycling (total 360 degree rotation of the solar magnetic sunspot polarity) they see a strong signal that seems to combine both the 11-year and 22 year cycle terminations closer together in this upcoming cycle.
What this means is that the end of both a 11-year and 22 year cycle - and their starting iteration into their new polarity - seems to show syncing per one Transform "Formula" but another shown by averages, seems weak and less intense cycle.
Stay Tuned!
So official forecast is low and other forecast is high.....only one way to find out...hurry up and wait :)
Just like the Weather Guessers it was WRONG Again.I just leave my radios On then I know when any band opens up.It takes the guess work out of it & I like the element of Surprise.{:>)
SIX-SHOOTER
