Turner +2 ssb mic pinout to HR-2510
Thanks for the reply!
Except for the FET, all parts appear to be identified on the schematic.
agreed, but, don'tee a thing on 'em.
There may well be a "number" imprinted on the FET??
see above statement
If the FET is good, it wouldn't be difficult to replace all of the other components.
agreed also
If there is a part number on the FET, that may be available or a suitable substitute could be used to replace it.
agreed again(grin)
Perhaps a complete board can be obtained from Icom??
going to make an inquiry tomorrow.
*I looked at the pict of the bottom of the board that a member sent me/posted just prior to him selling his mic. I noticed that there appears to be a wire out-of-place in comparison....Below is posted comparison picts. Where I have a white wire going to the "+" and ecm solder joint, a member posted a pict which shows a pink/white wire to same location. Ignore the detached blue wire I am holding...This mic worked when I stored it years ago when I stored it.
**MEMBERS BOARD PICT BELOW**
**MY BOARD PICT BELOW**
see above statement
agreed also
agreed again(grin)
UPDATE
I received a reply from ICOM and they indicate they do not have and do not manufacture the amp board for the ICOM mic...:censored:
So, this morning 02-06-2k21, I asked them if they used their own part numbers or, if part numbers are correct on components and am awaiting their reply.
Yesterday,I found a pict of my completed tower and antenna(s) and figured I would post it for your enjoyment or displeasure.....
On the top (horizontal) is a full wave 20 meter beam approx 40' x 30' with a 5'' boom.....I used to talk anywhere I wanted on just 30 watts...It is on the ground now and I have to repair broken/cracked insulators that are approaching the size of a football (American football, not soccer). (picts attached of insulators (not the broken ones)...Has anyone repaired insulators are large as these? how?
On the very top is a 10-11 meter Wilson Shooting Star antenna, which I had to destroy to take down the larger beam. I have all the parts (gamma matches, etc).
Enjoy....
  • @ Catalyst 122:
