I have been struggling with a suitable space for a 5/8 vertical. I had been looking at an old tv tripod on the house, others suggested that may lead to big problems. A friend of mine owns a roofing company, I am planning on redoing the roof in the next couple of years, he came out to give me an idea of the cost. He isn't an antenna expert, but we did take a look at the tripod and scoped out what it looked like in the attic, he thought the tripod has been up there since the 70s and was built to last. Hopefully I will find someone with more expertise when I redo the roof, see if it would be safe to put a vertical or a small beam on the tripod.
Saw this today and wondered who makes the mast:
https://www.worldwidedx.com/threads/diamond-x510hdm-station-upgrade.261510/
Looking through reviews, Channel Master and Easy Up aluminum masts look more suitable for TV antenna installation, Rohn push up masts are really hit or miss, judging by the reviews on eHam. Spiderbeam's push up masts look to be the best rated on eHam.
I have a 17.5' roofline, side of the house is brick. I'd rather not spend the $500 on an aluminum Spiderbeam mast, their fiberglass mast is more in my budget range. My plan is to bury pipe that the mast would slip over, bracket to the brick, and guy it. Would the Spiderbeam 12 meter mast be able to handle a Sirio Gain Master or should I save up for the aluminum type? I checked with local hardware stores, only carry 16 ga top rail in 10' sections. Found a fencing supply company that sells schedule 40 in 21' sections, I want to get at least 10 feet above the roofline, don't want to try connecting heavy top rail together.
Also have been eyeballing some trees in my backyard, but don't want to make a long coax run. Thanks for any help!!
