Does anyone know how to mod this rig to get 11 meters? Only info I have found was a youtube vid and my didn't come out the same. I think there is a bit more than just moving the pins. Stupid SMT!!!
Ya, and the radio drifts all over the band. But he gets to enjoy the shiny chrome, and brag about the 400 watts. Bling baby.$599+ for a 10 meter radio? I need to get into this stock.
Dis you see the link above?Hi...Is this for the 69FFB4 or the 69FFC4, I have the 69FFB4 and would like to know how to perform the conversion. Can someone help please?
THE OUTPUT IS A LOT LESS THAN EXPECTED!
R/f Power is your power output, this is variable with most radios, check a power metre for correct wattage.I RECENTLY AQUIRED ONE OF THESE ALREADY CONVERTED, HOWEVER THE OUTPUT IS A LOT LESS THAN EXPECTED! CAN ANYONE TELL ME WHICH POD TO TURN TO TURN UP THE AM OUTPUT? I DO SEE ONE THAT SAYS "A/F POWER" COULD THIS BE THE WATTAGE LEVEL ADJUSTMENT? THANK YOU IN ADVANCE I'M NOT THE TYPE TO WORK ON MY OWN RADIOS AND I HATE THE GOLDEN SCREWDRIVER SO I'M TRYING TO BE CAREFUL HERE
It's imperative you FEED THE BEAST to perform at it's top output.I RECENTLY AQUIRED ONE OF THESE ALREADY CONVERTED, HOWEVER THE OUTPUT IS A LOT LESS THAN EXPECTED! CAN ANYONE TELL ME WHICH POD TO TURN TO TURN UP THE AM OUTPUT? I DO SEE ONE THAT SAYS "A/F POWER" COULD THIS BE THE WATTAGE LEVEL ADJUSTMENT? THANK YOU IN ADVANCE I'M NOT THE TYPE TO WORK ON MY OWN RADIOS AND I HATE THE GOLDEN SCREWDRIVER SO I'M TRYING TO BE CAREFUL HERE
