Liquid Solder Mars mod questions
NightOwl3261
Well-Known Member
Jul 24, 2020
140
202
53
67
Due to aged eyes and ahakey hands I am going to do a Mars mod that requires connection a couple pads. What the heck product do I use ( specific please on brand, etc ) and does it require heat to cure, and if so what is the used as a heat source?
The only solder I would use for that is the solid variety.
Solid until you heat it with a soldering iron so it flows onto and bonds to the work surfaces. In your case, foil pads on a printed-circuit board.
I remember a "liquid solder" product from years ago. It was an epoxy glue that was saturated with metal particles.
Haven't seen it promoted in a long while. I have never tried to use it.
I concur with both of them. Use regular solder to bridge the pads and be done with it. Liquid solder is not what I would consider to be permanent for any electrical connection, especially in a mobile radio environment.
Reactions: Handy Andy
Sounds like you have a Yaesu 891. I did mine and I don’t have steady hands (69 years old). I put a pointed tip on my soldering iron, got it good and hot and only used a teensy bit of solder. Only took a sec. You got this. (y)
