Due to aged eyes and ahakey hands I am going to do a Mars mod that requires connection a couple pads. What the heck product do I use ( specific please on brand, etc ) and does it require heat to cure, and if so what is the used as a heat source?
Ok you talked me into it,.... I will do it the right way...
A large magnifier lamp helps. And resting the heel of your soldering-iron hand against a stable surface also helps if your hand just won't hold still. 73
