Well, I got the tubes all converted, installed and everything went very well there now on to the next issue I discovered, apparently the PO of the amplifier ran to many watts into the amp and or somthing else had happened as it looked like a lead on that little metal canister " what ever it is" was burnt completely away and there was also trace damage on the back of the circuit board coming from that component, what do you guys suggest I do to repair this, fix the original board or start over with another relay board like those on Ebay? I can tell someone else had done some previous soldering on this board
