I bought a 29ltd from @NightThumper a few months back that was done up by bells cb. I'm thinking it's a good recipient for an rdx95 donation so now scrolling though this thread for ideas to accompany the modification.
Off the top of my head, my favorite mods for the 29 are to reduce the negative feedback to the audio amp to increase the audio. This works great with the Astatic 636 and makes it loud like a power mic. Then another mod to reduce the modulation limiter attack rate to keep it from clamping and makes it essentially a compressor of sorts. I will see if I can dig up the thread.
Thank you sir,
Please explaine a little more on the audio amp mod as well. I remember you did a write up to that same type mod on the galaxy chassis so it's one to definitely consider.
The limiter mod sounds nice too.
Thank you sir,
Save yourself the time and bs modding your rig. If you want that big radio sound out of your 29 buy one of these and if you need you can make a couple adapter jumpers to use it on any radio you want. Total to your door is under $200 if you pay for the express shipping. Mine was here in a week...
www.worldwidedx.com
Basically the audio amp mod increases the audio gain. The max audio level is limited by the negative feedback resistor. The size of the resistor determines the gain and can be changed if you want to match the audio level you need. The mic level knob on the radio will allow you to turn it down if necessary on the fly too.
www.worldwidedx.com
