Galaxy dx99v No leds working
LawNad
New Member
Jan 29, 2023
6
10
3
68
Frequency counter, channel, and meter backlight all went out when I switched on the +10KHz. Can anyone tell me how to fix this?
Reactions: Rwb
The +10 switch itself is pretty simple. Regulated 9 Volts comes in one side, feeds out the other side to pin 9 of IC1, found on the "band" circuit board bolted to the side rail. Has to be a mechanical fault shorting that side of the switch to ground. A wire caught under a bracket and shorting to ground is what I would look for first.
Thanks, I will look.
Reactions: Rwb
Okay, I've visually checked for all the above. Removed the boards and inspected. Nothing. Time to find a good tech. Any recommendations?
Reactions: Rwb
Send @OldTech03 a pm. He did a great job with my 99v, it is now the main radio on my work bench in the back room.
Reactions: Rwb and tecnicoloco
99 V great radios. ever now n then need a lil tlc
Reactions: LawNad
