Service Tech for my Stalker IX
70cst
Well-Known Member
Dec 4, 2009
627
188
53
74
Ok ... who would be a good service tech to go through my Stalker ... it’s going to need a new plastic window ... but who knows what other things one might find. I want to hook it up to my Gray 300 but before I do that I want to have the radio checked out. Thanks in advance.
servicing the radio should be well within the skill set of quite a few techs.
your main issue would be that cracked plastic because unless someone has another stalker 9 to pull from, i think you're out of luck on that one.
its the plastic that goes over the meter, LEDs and channel display right?
or am i incorrect and it's just the actual meter face that's cracked?
This place is not too far away for you. I know at one point Doug was doing older radio restorations. Worth checking into.
Here is another much closer option.
Thanks for the info
