Ok @unit_399 I completed the mod you advised.
(Eagle eyed viewers may note the diode is standing way up in the air - took the picture before I substantially lowered its position) on the plus side makes it easy to see the changes. Resistor to diode and old blue cap to green cap.
Locate D23 (next to VR7). In the Realistic rigs a 220 ohm resistor is in the D23 location. Replace this resistor with a 1N914 or 1N4148 diode. (observe polarity). This change will make the Realistic 858 mod limiter the same as all of the other brands. Really opens up the audio. Replace C87 with a 10uF 16v electrolytic cap.
My question is what did I actually do by changing the circuit as you said, to match the Uniden circuit? Replaced the resistor with a NTE diode and the cap with a nichicon audio grade cap.
I am told I have great audio but then I did prior to the mod as well. Either way thank you for the knowledge and advice.
