Which big black base should I get?
If you decide on a "high watt" 10 meter mobile radio converted for 11 meters, be certain you don't get the cart before you buy the horse. Translation: First, get a decent power supply for the radio of choice.
So what power supply do you get along with?
I am the wrong guy to ask because I'm an "overkill" guy when I buy anything.
I have an ASTRON VS-70M power supply which will handle just about anything.
Someone will reply with a few recommendations.
Reactions: Keto
This is the 30 amp supply I got so far it doing what I needed for a Stryker 955. Simple and quiet.1000009865.jpg
Really similar to yours above
I've ran the alinco dm-330mvt as my station supply for about 4 years and handles most radios without breaking a sweat. I won't even try the radios with a built in amp though.
You've got tons of headroom to run that Stryker.
Reactions: Keto
Good to know your Alinco is lasting.
Headroom was what I was shooting for. When I add to the radio or a have a high watt I'll have to go bigger.
I've just used the 13.8 v preset setting, figure I could bump that up some, radio shows 14.1 though
Guess I should test it to see I'd the digital is off?
One of the two is off, a dvm would give that away. If it's the supply, it's not enough to cause a problem at least.
Reactions: Keto
Checked the volts out from the supply 13.8. and the put it in variable mode. The 955 radio is always .2 volt higher from the Meter and supply.
Probably a way to correct that, seem like I've seen it on a video. Not a big deal but annoying detail.
It's in the service menu somewhere but I've never messed around in there so I can't tell you how.
Here it is at the 7 minute mark.
Aah , service menu. I thought it was on a video I've seen. I'll not mess around with that. Thanks for the info.
What voltage do you run something like this at?
Edit: After watching the video again, I went into the service menu and up to the voltage readout # and dropped it .2 and now the multimeter. Power supply and radio all line up. Thanks!
