I'm Looking to buy a driver at least 100 Watt out PEP, for a 6 Pill.
mitch169
Jun 14, 2023
27
20
13
65
It must have an SSB delay.
Mitch
Might matter how much drive wattage you wish to use with this amplifier. A radio that's big enough will sound better driving the big box directly. Even a small one will, but might disappoint with the wattmeter reading.
I think the gap you seek to fill between the radio and amplifier might be too small to justify adding another amplifier.
Unless the radio is a stock 40 year old Cobra 2000GTL busting a gut to swing 13 Watt peaks. That would no doubt call for a driver.
Reactions: Catalyst 122
Yes, the main radio is a Flex 50000a putting out 65 watts.
Then I would need a driver once I finish the restoration of the Browning Golden Eagle Mark III, which puts out about 10 watts. Then I would need one. I don't want to drive the box hard. The previous owner didn't, I asked this question thinking the box would need 100 watts to drive it.
Carlbuilt C60 mobile with biasing $220 plus shipping. Does have variable. Will need a small power supply. The C80 with biasing for $235 would work too with the six.
Can't remember seeing a 6-transistor linear with proper bias for clean sideband. Just accustomed to that design setup as being a AM thing.
The "powers of 2" style, with two, four, eight or sixteen is more what I'm used to seeing in sidebandland.
Who made this one?
