extra license
1iwilly
Dec 7, 2008
915
653
103
64
I'm trying to study for the extra license after lesson 11 it has become hard to focus on the rest of the lessons confusing to me to try and remember the questions and answers. brain fog
Remember, you don't get "extra" points for getting a high score on the test - it's pass/fail. My advice is to skip the parts that are giving you trouble right now and move onto another subject. Then start taking the practice tests to see if you can pass, and if not, which sections you need to focus on.
Any local community colleges in your area have ham study classes? Might even be free depending upon your financial situation.
CQ Contest CQ Contest CQ Contest CQ Contest CQ Contest CQ Contest
You get the idea. I wanted the extra to VE anybody. My way of giving back.
Reactions: Naysayer
Please elaborate... I'm always open to different methods of accomplishing something.
You can always have the book and materials to refer to if you need any information......
BUT, to take and pass the exam test for the license, you only need to study the materials that are actually on the test. As you may know, the test question pool changes every few years. But the actual material never changes, only the pool of questions.......
So, I suggest the following.......
Study only the questions that can possibly be on the exam......
Then take your practice exams here. The format on this site is very similar to the actual exam......
Take the practice test over and over and over and over again....
The questions change each test, but the goal is to get used to seeing the correct answer to each question and block out the other three answers.
Keep at the practice test over and over again.
When you get to the point you can pass any test with at least 90% grade, then you are ready to go see your VEC and get your extra.......
DON'T study material that is not in the question pool........
Good luck and enjoy......
