Home Elecraft K4D Noise Reduction compared to BHI NR module
Ham Radio Nerd
Apr 14, 2002
9,339
2,041
383
I've owned the Elecraft K4D for a while now. It's a wonderful rig. However, I am deeply disappointed in the NR capabilities on SSB and several have brought this up on the various Elecraft forums. Wayne N6KR, one of the Principals of Elecraft has commented that they intend to improve it by adding spectral subtraction algorithms, but for now it's basically a copy/paste of the code from the older K3 rig. I got tired of waiting around and decided to improve the situation by trying out the BHI Dual In-Line Noise Eliminating Module.
Because the Elecraft K4D has stereo speaker / headphone output (which is used in a variety of ways), it was important to me to buy this specific BHI box, which supports both external stereo speakers and stereo headphones. They can be used independently or together and even have separate volume controls. I shot a brief video doing a quick demonstration of both unit's NR capabilities, as well as using them both together. Note that I could have made additional adjustments on the BHI module, but I felt the demonstration was good enough as is. To keep the comparison on a level playing field, I made no additional adjustments on the K4 other than adjusting the volume as needed.
What do you think?
Reactions: AudioShockwav
I use the BHI & ClearSpeech DSP modules or DSP Speakers with every radio I own that does SSB or AM & that includes my ICOM 7610,ICOM 9100,ICOM 7000,& ICOM 703+. I HATE noise so I do what I can to remove any & all of it that I possibly can. I have never heard ANY radio that can compare to the external DSP units. I understand that they are two different types of DSP but the radio manufactures should take notes & add both types to their radios. NOISE SUCKS & it makes Listening stressful on your ears. You can't work what you can't hear.
Reactions: N0NB
I found the built-in NR worked better on speech but didn’t clean up steady background noise as well. Playing with the settings helped some, especially adjusting the threshold and level.
I am now using the ClearSpeech DSP module with my YAESU FT-920 as a backup radio & it really helps it. I don't believe the AF DSP in the 920 is up to what the IF DSP is in the ICOM radios, so the external DSP makes a bigger difference on the received signals. I own the same Dual Inline unit pictured as well. It's great for the ICOM 7610 or the ICOM 9100 that have Dual Receivers, so I only need one DSP unit for the radio.
I had decent results tackling background shack noise by lining parts of my operating desk and radio shelf with auto sound deadening mat. It didn’t help with RF or digital hash, but it really cut down on fan noise and rattles, which made a difference when listening at low volumes. Pairing that with DSP onboard makes long sessions less fatiguing for sure.
I use a Quality Studio Microphone that does not pick up most background noises. The HEIL FIN with my ICOM 7610, Electro Voice RE 320 with my ICOM 9100, HEIL PR20 on many radios, & HEIL iCM on my older ICOM radios are very very good at cancelling the background noises.
Have any of the more recent K4 updates improved the NR?
The one thing that disappoints me about my K3 after 15 years is the useless NR on voice. I'll put the poor autonotch at #2. I am fortunate to have a rather low noise environment but there are times when a functioning NR would be useful.
The K4 now has Spectral Subtraction Noise Reduction (SSNR) as of beta release R38.BETA3. There are many favorable comments on the K4 forum including comparisons to BHI, etc.
I installed the new firmware with SSNR the day it came out and ran some quick tests. It's amazing. I will post a new video and thread comparing the original NR and the BHI and the SSNR with combinations of the three (if possible). One thing I really like about the new SSNR is that the recovery time from it attacking a signal back to dead air is very pleasant. That was always one issue with the BHI that I tolerated...
Reactions: Dr. Frankenstein
Here's a new post I started discussing the new SSNR in the K4:
Wow! It's about time somebody did it that way. A long, long time ago I wanted to find a way to do that in hardware. The "Lamb" blanker every Cobra and RCI SSB CB uses does this in the amplitude domain. I wanted to do it in the frequency domain. Never found a way.
Bravo Elecraft!
I Sold the Yaes
I am now using the ClearSpeech DSP module with my YAESU FT-920 as a backup radio & it really helps it. I don't believe the AF DSP in the 920 is up to what the IF DSP is in the ICOM radios, so the external DSP makes a bigger difference on the received signals. I own the same Dual Inline unit pictured as well. It's great for the ICOM 7610 or the ICOM 9100 that have Dual Receivers, so I only need one DSP unit for the radio.an ICOM 775DSP & I still use the ClearSpeech base module with it & I run it thru (2) ICOM SP-20 external speakers the have the PHIT speaker & foam kits in them. The sound is Amazing & the speakers sound better than any I have ever heard or used.
Sold the FT-920 & replaced it with an ICOM 775DSP. I am using Dual ICOM SP-20 external speakers which both have the PHITS speaker kits installed & the speakers are running thru the ClearSpeech Base Module. The sound is Amazing & unlike any I have ever heard. The DSP units are a totally different type of DSP from those in the radios, so they work together in removing noise in the received audio. I'm not operating without them on any of my radios.
