Anytone At-6666 Pro
A healthy car battery should deliver 12.6 volts when the car is off. So if the CB gives you this alarm when the engine is off but there are no problems when the car is running, it means your battery voltage is insufficient. Therefore, the battery is old or needs to be replaced.
Yeah your probably right and I can't remember when I changed that battery. It doesn't seem like it was that long ago, but then again time flies when your having Fun ! Maybe it's time to get my load tester out and check it before winter gets here.
I just ordered another QT80 direct from Radioddity. I figure with the tariffs and all, now would be a good time before the prices go up 25-50%. I'll put this one up on the shelf just in case we won't be able to get any in the future. These are still the best 10/11m radios ever, and that's saying something since I've pretty much had 'em all. See you on the bands!
how was your experience ordering direct? i see they have the qt80 in a bundle sale for $239
jumped. $258 out the door. cheaper than trying to make a good ssb rig out of the old 2980. variable nrc that i wish my k-po dx5000 had.
I wish someone would make an affordable NRC module that I could put in my old Galaxies. These new radios have spoiled me and it's hard to go back.
No bigger than say the west mountain clr dsp module is, it could be roughly the size of an echo board. Use a dual control pot with an on/off on the inner knob, power ground to the board, in and out on for audio on the speaker trace and we could be golden.
We just need someone to build it!
That could be a really nice add on for our ranger, galaxy radios.
