WHATS THE POINT re, QT40
HomerBB
Jan 4, 2009
4,009
2,801
273
70
Rogers, Ar
I bought one. I did the jumper conversion to CB. What's the point of the software if that jumper move is all it takes to make the conversion. I don't want it to do repeaters.
Also, the thing returns to receive after unkeying the mic very slowly... radio seems to work in sloth mode.
Plain english answers, please.
1. Do I need the software to complete the 11m conversion, and
2. Why bother with the software if the answer to #1 is "no".
The conversion is not in software. The CPS, makes it easier to do some of the functions, like memory channels, CTCSS/DCS, offsets and such. Also, easier to set the radio up with the CPS, as opposed to the function menu. All of the fucntions/options are right there, in front of you, without digging through menus. Once the radio is set up to your liking, you can save the setup configuration as a file. Should you ever need to reset the radio, you can restore all of your settings from that saved config file.
I also figured out the delay in receive after unveiling was caused by the SWR function being on. I turned it off and the delay went away. I also turned off the roger beep. I did not hear it (I don't run talkback), but could see the movement of the rf meter.
So far, getting good reports, and making contacts easily. Seems to have great receive.
Mic feels a little lightweight, but works okay. I do like the classic CB look.
If you look at the front of this Galaxy DX88 you'll see the band dial with double band letters in 4 positions. One set of 4 band letters are "high" bands, and the other 4 are "low" band letters. Just above the band selector dial you see a button that reads off & low. When pressed to low, you get access to 4 of the bands on the selector switch, when in the off position, you access the other 4 bands on the selector switch. One set is A-D, the other is E-H.
The band switch on the QT40 is for different bands when switched to H or L using the same band selector knob marked A-F similarly to the Galaxy DX88. You need a channel chart ( road map) to know where you are. Once modified for CB the switch is on L, and the dial is on D for channels 1 (26.965) through 40 (27.405). Of course, selecting WX on the switch accesses the NOAA weather frequencies.
Hi Homer, long time no see! Not sure about the 40, but I have the QT-80 that I won here. I don't use a beep either, but fyi you can't hear the roger beep with the talkback on with the QT-80. You CAN program up to 8 different ones, with up to 14 different tones, along with infinite changes to individual tone length via the CPS. As if the Stryker ones weren't annoying enough. :LOL:
73,
Brett
Reactions: AudioShockwav
I picked one up and noticed the manual is a little out of date. Manual states to hold down up/down to start scanning. I didn’t realize til after reading the above comment that it’s actually reading out the frequency in 3 flashes [27] [38] [[50] …good Lord ‍♂️.
Secondly, Fine Frequemcy Range was not even a menu option (5kc slide).
I downloaded a new manual from their site. https://radioddity.s3.amazonaws.com/Radioddity_QT40_Mannual_20230425.pdf
SSB a little hot on scope @ 40+ watts pep
Looks better at 32 watts pep. Meh
AM looks very nice out of the box. Scope looked like flat topping until I zoomed in on the wave.
One dumb quirk: Having to turn off radio and hold up button while turning on radio to enter menu mode.
Receive is noticeably better than my Icom, both by the ear as well as SINAD.
People like to poop on the QT40 but for like $149 they are diamonds in the rough! Perfect? Nope! Darn good though.
If the people in the know actualy applied themselves to this radio it could be great but their is no money in it for them so no attention. Probably good that they do not or it would be like the Redneck Fantasy radio the Sryker 955 and be a $700 radio after modifications!LOL What did Phineas Taylor Barnum say about a fool and his money???
