NPC RC modification mod
Eldorado, if you have a scope, can you tell us what the negative peaks look like with this mod?
I believe that it will show them not even achieving 90%.
@loosecannon
I sold that radio back in December so I don't have it anymore. It was a good talking radio and I got many unsolicited compliments on how strong the audio was when I had it in service.
Anyways, as with all the radios I own I pulled off the covers to see the goodies and to take pictures. I assumed it was the NPC mod at that time but hadn't asked until I ran across the photo today.
I've thought about trying it with the 2950dx6 that I still have so another reason I was asking.
It appears to be a 100 ohm smd resistor but the diode I have no idea what it is. The 2950dx6 has a very similar board so if I can decode the diode in the photo I'll give it a shot and report back.
By the way, that work in the photo was done by Brian at Trucks CB on the 2995dxcf
the diode is a regular old 1N4148 or similar.
Ive done this mod to a few new style 2995s and found that any resistor value wouldn't allow the negative peaks to reach near 100%.
i ended up just using the diode alone.
however, i do not clip any limiters when i do this mod. Trucks may have additional things done/removed.
Reactions: Eldorado828
Thanks for the info on the diode. I had looked over the component side of the board really well and couldn't find anything swapped and all limiter were also intact. Unless I missed something, that was all he had done to it. The 2995 dxcf did have some strong audio.
