Anytone AT 5000
Just getting familiar with this radio and I'm trying to figure out what all of the items in the display are telling me. Here's the LCD with everything shown.
The manual has some things explained like the yellow S which indicates that the current channel is in the scan list. I see the R come on whenever SSB is selected, but what does this mean? I have not seen the green + come on, or the red A, or the T and none of those are described in the manual. Anyone here that can help explain the meaning of these? Sorry if these are newb questions.
R (in SSB) is for RX Clarifier. (You can set this for OFF, R, T or R+T in the menu).
The "S + A" area of the screen is for showing Scan, Offset, and Scan ADD.
The CPS (Programming software) is not ready for release yet, but it will be soon. It will appear on the AnyTone website as soon as it is available for download.
Thanks, all clear now!
I interesting video from @BlueBeam on this one.
( Aka Panic attack)
Thanks for the video links. Really glad to see that there is a VFO mode! Not mentioned in the manual. Press FUNC then press and hold BAND. VFO displayed, and the steps can be changed by pressing the push key then turning it to select the step. Also downloaded and installed the programing software. There's a pull down for the CB/HF/HAM selection, but only CB is shown in the drop down list. Don't have the radio connected, maybe when I do since I moved the jumper to make HAM selectable it will give me all three options.
Make sure you have moved the jumper inside the radio, then read the radio with the CPS (programming software). Only then will these options become available in the drop-down list.
