Anytone AT 5000
Just getting familiar with this radio and I'm trying to figure out what all of the items in the display are telling me. Here's the LCD with everything shown.
The manual has some things explained like the yellow S which indicates that the current channel is in the scan list. I see the R come on whenever SSB is selected, but what does this mean? I have not seen the green + come on, or the red A, or the T and none of those are described in the manual. Anyone here that can help explain the meaning of these? Sorry if these are newb questions.
R (in SSB) is for RX Clarifier. (You can set this for OFF, R, T or R+T in the menu).
The "S + A" area of the screen is for showing Scan, Offset, and Scan ADD.
The CPS (Programming software) is not ready for release yet, but it will be soon. It will appear on the AnyTone website as soon as it is available for download.
Thanks, all clear now!
I interesting video from @BlueBeam on this one.
( Aka Panic attack)
Thanks for the video links. Really glad to see that there is a VFO mode! Not mentioned in the manual. Press FUNC then press and hold BAND. VFO displayed, and the steps can be changed by pressing the push key then turning it to select the step. Also downloaded and installed the programing software. There's a pull down for the CB/HF/HAM selection, but only CB is shown in the drop down list. Don't have the radio connected, maybe when I do since I moved the jumper to make HAM selectable it will give me all three options.
Make sure you have moved the jumper inside the radio, then read the radio with the CPS (programming software). Only then will these options become available in the drop-down list.
Should have one coming in a week or so. Form factor was a big piece of the decision, probably going to pair it with an RT95 for a portable/UTV set up.
For those that might be interested, I extracted some of the pages from the anytone spreadsheet that describes AT-5000 frequency expansion. I'm attaching .PDF files for each of the sheets. One is the expansion process, the others are the channels in the bands associated with CB, HAM, and HF modes.
Just got mine in, ordered on Amazon & shipped by Anytone (from Canada). At time of order, that option promised quicker delivery than one shipped by Amazon. Arrived intact, no shipping damage, no customs duty.
Cover with speaker does not have a "warranty void if broken" seal. Opened it using a T8 torx bit. Jumper was on 1-2 (as expected for locked down CB mode), moved it to 2-3 to enable HAM/HF modes & re-installed cover.
Accessories in box included the programming cable
. Power cable does not include a disconnect option, just an in-line fuse on the red (+) lead.
EDITED TO ADD: A printed manual is in the box, but only covers the CB configuration - does not cover HF/HAM differences regarding freqs or power.
Not sure when I'll take the time to play with it other than doing some configuration. I'm working on a possible portable HF antenna build, uses a 20' fiberglass pushup & some telescopic whips. Final form will include clamp-on tripod legs & screw-on antenna base. Might do an elevated V.
Wanted to clarify/correct portions of the instructions for frequency expansion/band control found in the .xslx file provided by anytone. Note that this information is not present in the user manual.
To select a CB/HAM/HF mode (after jumper moved to 3-2), press and hold FUNC during power up, then release. Use the knob or arrows to select mode. Press & hold power button to power off. Chosen mode will be present on subsequent power up.
The original text for band changing included the following "Press and hold FUNC+BAND until the current band is flashing". That does not work.
To change bands, click the FUNC key, a "FUNC" message appears at the top of the display, while it is present, click the BAND key. That will cause the current band value to start flashing. Use the arrows or knob to change the value to the desired one.
VFO mode is not mentioned in the text. Access VFO mode by clicking FUNC, while the "FUNC" message appears at the display top, press and hold the band key. VFO will appear in place of the channel number. Repeat the process to exit VFO mode.
Granularity of the VFO is controlled by clicks on the knob to change the position of the value to change.
So for you gents tha t have have the at-5000 for a few weeks now, how has it performed. I guess I'm kind of asking for a report as to how well it works and if there's any weird quirks discovered yet.
I've been eyeballing one of these for a bit.
Mine works great, no glitches or bugs so far. I had it set up in the shack and used it every day, the menu setup is better than some other menu driven radios. It has the same great audio as the other Anytone radios, and selectable 4k transmit audio. Noise reduction works great, as expected. It has 3 power levels, and does 25w peak on high. I am getting ready to buy another one as a backup.
Reactions: Eldorado828
