Galaxy DX2517 Troubleshooting Help
i think your problem lies in the circuit containing Q30, Q31, and Q33.
i know you said you already checked them but any experienced tech will tell you that it's always the thing you're already sure its not.
It takes some doing to get the right info for a situation like this because its a ranger radio and none of their service manuals have voltage charts for the semiconductors.
the good news is that these chassis are all very similar to each other, and luckily with this particular circuit they only changed the part numbers.
so if you go look at a service manual for an old galaxy 99v, you'll find the voltage chart, and then you just have to compare the schematics to cross-reference the part numbers.
im going to bet that you won't read the voltages i post here because your radio is stuck in "both" TX and RX, but it could still help.
so measure the voltages on one of the transistors, and if/when you find that it isn't right, pull that transistor out and test it. you might want to post your testing method here to be sure you're doing it right.
here's what the voltages should be:
Q30 is a 2SA1282 PNP transistor that is an E C B if you look at it facing you.
in RX: E=8.55v C=8.52v B=7.8v
in TX the only voltage that changes is C which should be 0 volts in TX.
Q31 is a 2SC945 NPN transistor and is also an E C B.
in RX: E=0v C=.10v B=.70v
in TX: E=0v C=8v B=0v
(the B might be the opposite on RX and TX as there may be a typo in the info im looking at)
Q33 is a 2SA1282 PNP transistor and is E C B.
(BTW these can a be a bit hard to find these days)
in RX: E=8.55v C=0v B=8.03v
in TX: E=8.55v C=8.37v B=7.75v
i think you're going to find one of these parts shorted and i think its going to be Q33 but that's just a guess.
Got a chance to work on it tonight.
Q30 and Q33 have been changed with transistors from another galaxy that had no switching issues. D71,72,73,59 have been replaced with 3 series 4148 diodes. d70 replaced, Q37 Q55 Q54 have been replaced with parts from rfparts or ica manufacturing or trucks cb sales. Q30,Q33 voltages are identical from left to right the voltages are 9.47, 9.42, 8.73V. Q37 voltages from left to right leg is 12.90,9.80, 13.60. Q35 voltages from left to right are 2v, 12.91v, 12.38v. I analyzed the schematic around those voltages for a bit but have to call it a night. There are some electrolytic capacitors around the q35 q37 ic7 area that I may work on pulling to check and replace tomorrow since I haven't found a problem yet. will hopefully get back on it again tomorrow. Hopefully some of these voltages will give some clues. Also, Q31 and Q35 have been replaced with 2sc1815 transistors out of an assortment from amazon. From what I looked up it said it was a direct replacement for the 2sc945. Hopefully using those aren't a problem. Another voltage I read was 2 volts on the positive lead of D72.
Your voltages on Q35 are a little confusing. Left to right is ECB, so 2v at emitter, 12.91v at the collector, and 12.38v at the base. The first two make sense, but that base voltage doesn't look right. Since we are getting a reasonable voltage from Q37, I will consider it a typo.
The issue of both RX and TX would be independent of that regulator though, so we need to figure out why Q33 is turning on in RX.
Looking back at post #6, I see you reported fluctuating voltages on the op-amp pins. Pin 6 fluctuating slightly and pins 5 and 7 fluctuating heavily points me directly to pin 6. A slight fluctuation there will cause a large fluctuation in the output and also pin 5 due to the hysteresis feedback resistor.
Here's my guess. Something at the PLL is causing the lock detect to oscillate or send pulses. This causes the RX/TX switch to oscillate. I'd bet that RX and TX are not on at the same time, rather oscillating back and forth giving the impression that they are both on. The rail capacitors probably hide the oscillations from Q30 and Q33.
To test this theory, lift one leg of D60 and see if the TX light shuts off. Don't operate it like this though, it's just a test. I am going to bet that C103 went dry or something at the PLL is causing this.
To test this theory, lift one leg of D60 and see if the TX light shuts off. Don't operate it like this though, it's just a test. I am going to bet that C103 went dry and is not smoothing the PD pulses.
Okay, I will try this this evening when I work on it and get back with what I find out after lifting d60. Last night I did have Q30 out and tried turning it on and the green light went out and was only red. That may be normal since it was out but just thought I'd mention it. Thanks for the help so far.
Also the guy I'm helping who owns the radio had it on for 17 years straight without ever turning it off because he leaves it on downstairs so he can use it upstairs and is too old to go downstairs to turn it off and on. Don't ask me why he does that lol that is just what he told me. Im surprised it even stayed on that long without problems.
Reactions: brandon7861
To further support my theory of a pulsing lock detect, from the PLL datasheet...
There must be a McGyver way to evesdrop on that without a 'scope. But a 'scope is the only way I know to ID that fault. This radio demostrates the value of the 30-buck fleabay transistor tester. If your time is worth anything at all, it's a good bang for the buck.
Computer sound card using the line-in jack and a program like friture could probably do it. It's probably got a blocking capacitor so it won't see DC stuff, but anything between 20Hz and 20kHz should be possible. Just be sure it isn't sourcing phantom/electret mic power first. Most sound cards I've seen allow line-in to do other things like that and some even auto detect, so make sure there isn't DC coming out first.
I'd bet those pulses are 10kHz just like the PD freq. And a receiver could hear the rest of the signals. Definitely not as fun as using a real scope, but maybe if one were desperate enough...
I do have a scope and a real cheap transistor checker if that would help me. How can I use them to find the problem like you are mentioning?
I do have crt and cheap digital scopes, how would one go about using it to find the problem you are describing?
Start by putting everything back together around Q30-37 and lifting one leg of D60. See if the red light goes out with D60 lifted. If it does go back to RX, we will know the problem is at the PLL, and you can then put D60 back. Once we know the problem is at the PLL, we will move over there and continue with your oscilloscope.
C103 tested good but replaced it anyways last night. I just lifted one leg of d60 and it did not change the way the light acted on the front. It is mostly lit up green but I can see the red light is partially on a little at the same time and comes on and off a little. Also now the frequency counter fluctuates around 31.5mhz no matter what channel or band it's on and did not do that before..
is that with D60 in or out or both ways?
Are the voltages at pin 5, 6, and 7 of the op amp stable with D60 lifted or are they still fluctuating? I am not familiar enough with this radio to to say for sure, but I recommend using board ground, not chassis ground, when measuring those pins. Pin 4 of the op amp is ground.
Edit to add: when parts test good, put them back in. Don't replace them.
What I am currently worried about is getting stable signals around the op amp so we can get accurate voltage readings and see what the switching transistors see. If this part is working fine, something else is feeding that TX side and we will need to find it. But before we go hunting that down, I think we need stable op amp voltages. The 35MHz thing doesn't really matter until we know what is causing the switching issue.
Voltages w/D60 lifted:
Pin 1-5.45v Pin 8-Fluctuates around 8 and 9 volts
Pin 2-5.03v Pin 7-Heavily fluctuates from roughly 6.5 to 7.5v
Pin 3-5.03v Pin 6-Fluctuates from roughly 300mv to 600mv
Pin 4-0 Pin 5-Heavily fluctuates from roughly 1 to 3.5v
Voltages w/D60 not lifted:
Pin 1-8.34v Pin 8-8.9v
Pin 2-Fluctuates around 2 to 3v Pin7-Fluctuates around 7.6 to 8v
Pin 3-4.90v Pin 6-Fluctuates around 1 to 1.5v
Pin 4-0 Pin 5-Fluctuates around 2.8 to 3.2v
It seems like the only real difference would be the 3 volt difference on pin 1. Minor differences could be because the fluctuating voltage are so unstable and the longer I leave the lead on the pin to read the voltage the more the voltage fluctuates. I keyed up on a nearby radio and the galaxy radio does receive the signal on the meter now but there is no receive audio. I mentioned it was reading around 31.5mhz but that is intermittent and will randomly go back to the correct channel frequency with minimal fluctuation. There is also a bit of a low intermittent screech or static like sound coming from the speaker when it's on.
Pin 8 is the supply. With it fluctuating, I am curious if it is fluctuating at the regulator or just at the op-amp. I think it may be fluctuating only after its 100ohm supply resistor (R174) due to the load it is trying to drive (as R174 will drop some voltage under load).
Just to be sure that this fluctuation is not coming from the regulator, confirm there is a steady voltage at Q37's collector.
If indeed there is a 1v variation across R174, that means something is drawing up to 10mA through the op-amp. Since the op-amp is sourcing 10mA and not syncing it (supply pin sagging), I look whether or not the surrounding circuit can explain such a draw. With a working Q33, I don't see how. All of the resistors around the op amp are too large to support the idea of 10mA going through them at low voltage, so I would be suspecting the op-amp in this case.
Maybe its time to take your o'scope to the supply pin and get a better look at the waveform. If the high side of the op-amp output buffer is shorted, it will draw a lot of current when the output tries to go low.
edit: When you say 8-9v fluctuating on pin 8, I understand that might not mean a full volt swing across R174. just brainstorming with what info I have.
The collector, middle leg of Q37, is slowly fluctuating anywhere from 9.5 to 11.5 volts. Also, the current draw on the power supply for the radio fluctuates from 0.45 to 0.75 amps when powered on.
