Forgot to mention my setup.
- Anytone AT-55555N II radio (short model)
- Sirio 827 ground-plane antenna wit nylon anti-resonating ring (against the noisy winds, living at the coastal line of the North Sea)
- RG-213 coax, Bedea (Berkenhoff & Drebes, Germany), 15 meters
- Messi & Paoloni PL-269 compression connectors (Italy)
- Heatkit HM-2102 pwr/swr- meter (Benton Harbor, U.S.A., bought off eBay), partially rebuild and calibrated and a digital one, SureCom, SW102-HF (Aliexpress) witch has a changed Li-Ion batterypack also replaced by me with a 1000mAh type, was standard 550mAh (Aliexpress). SureCom advertised the unit with a 880mAh batterypack, no such thing though.
- Common Mode chokes, 3 pieces total (ideal should be 5 pieces) mounted at the feedpoint of the antenna, brand Fairite, mix31, clamp-on type (U.S.A.)
- Common Mode filter on the other side of the cable/coax, diy- kit from HF Kits Netherlands with a FT240-31 toroid
- Standard 30A/13,8VDC switched mode power supply (K-PO) modified by me and has now a removed cigarette ligtherplug (female) was on the frontside witch created a massive groud-loop in the unit itself (!), added a dc- filter on the 4mm bananaplug studs inside for extra dc- filtering and changed some component values also witch leaves me now with a 35Amps/13,8VDC small, efficient power supply with almost any noticable RFI by-products. Checked this with a tiny Spectrum Analyser (Aliexpress) and remarkable no excessive heat.
- For backup a President Teddy II little 4 watts AM/FM tranceiver, modified (Jumper re-placed and one cut wire), by the way, a nice little unit and proudly made in the U.S.A..
QTH, Netherlands (Europe)
This should do for now I hope.
Regards.
