Anytone at-5555n II (version 2)
No, extended VHF is only available on the short case version.
Yes, the "official release" firmware is good to go, but it is the older factory firmware that does NOT include the latest features. It was added here in case anyone wished to roll back, for any reason.
If you want the latest and full feature set available, use the latest and final firmware version linked below. (It has proven to be safe with no issues reported so far, despite the general warnings I had to add to the post):
ok so the beta is the MODIFIED version and USE AT YOUR OWN RISK. and the LATEST/FINAL FIRMWARE is the original version in case the BETA version doesnt work on your radio.. YES?
No need to yell. That is correct....the beta is the updated software to run on the "long case" 5555N2 which gives it most of the abilities of the short case version. The other software posted later in the thread is to roll back to the original firmware if you have problems.
The upgrading process is very very easy. Follow Pez' instructions exactly and you won't have any problems. Note that some very early 5555N2's may have issues with the upgrade...the info on which those are is in the thread too. Good Luck!
Good evening all,
Just a couple of small questions regarding my AT-5555 N II. How do I determine if I (own) have a "short" or "long"- case model? Next, how do I preform a hard reset on the unit? The OPT menu function (reset according the manual) should do the trick, however I'am not 100% this gives me the wanted result(s), because I see no changes. And for the last one, how in the world do I access the "hidden" features/menu? There are so much answers and before going to try all of them I fear it does my state of mind no good to go experimenting with all these found "solutions" and Youtube- videos as found on the Internet. Please help.
TIA.
Good evening all,
TIA.
Hi Hans:
See the picture below for the size difference.
What are the "wanted" reset results you want to see?
For reset, there is two options, OPT and ALL (rotate the CH knob). ALL is what you want, it will reset the menu and factory channel settings.
Regarding the "hidden" menu - I strongly advise you do NOT play with this. A Reset does NOT restore any changes you make in there - they are locked in and there to stay. If you do not have all the required test equipment and knowledge, I suggest you stay out of the hidden service / debug menu.
@Pez; Thank you kindly, it seems I have the short version thus that would mean that I have the/a latest or newest model. Good! Thank you for the reset "ALL" option, couldn't find it first, so here also a big thank you for mentioning.
Ah, I see about the "hidden" feat menu (no go to factory defaul etc.) can I conclude that all the settings in this special menu are correct? I've read somewhere that the mic. setting can or must be adjusted for better response (?) on the receiving end. Well hope to hear. Also read that one MUST write down the all the current values in this hidden menu before changing anything, hence the fact that you've also mentioned this that there's no restoring to factory defaults, a one way street so to speak... bummer.
No firmware upgrade too? Anytone did a good job then creating and programming this type of radio before it left the production plant!
Thanks for your time, attention and do have a nice weekend.
Reactions: Pez
Hi Hans, you're welcome.
The only thing you might want to do, is adjust in the normal menu (not the hidden service menu), the the "MIC" gain, "TONE" for SSB, and "FMDEV" for FM, and you will be good to go.
FYI- some of the settings in the hidden menu can be accidentally cleared, and then you can not enter these back in (even if you write them down), without using test equipment. This is why we always caution folks about this menu!
The firmware had a couple of revisions shortly after it was first released, but now it's pretty solid and has not had any new updates for some time. It's a solid performer out of the box, with no adjustments needed for a good time.
Have a good weekend. Good DX!
Pez
Forgot to mention my setup.
- Anytone AT-55555N II radio (short model)
- Sirio 827 ground-plane antenna wit nylon anti-resonating ring (against the noisy winds, living at the coastal line of the North Sea)
- RG-213 coax, Bedea (Berkenhoff & Drebes, Germany), 15 meters
- Messi & Paoloni PL-269 compression connectors (Italy)
- Heatkit HM-2102 pwr/swr- meter (Benton Harbor, U.S.A., bought off eBay), partially rebuild and calibrated and a digital one, SureCom, SW102-HF (Aliexpress) witch has a changed Li-Ion batterypack also replaced by me with a 1000mAh type, was standard 550mAh (Aliexpress). SureCom advertised the unit with a 880mAh batterypack, no such thing though.
- Common Mode chokes, 3 pieces total (ideal should be 5 pieces) mounted at the feedpoint of the antenna, brand Fairite, mix31, clamp-on type (U.S.A.)
- Common Mode filter on the other side of the cable/coax, diy- kit from HF Kits Netherlands with a FT240-31 toroid
- Standard 30A/13,8VDC switched mode power supply (K-PO) modified by me and has now a removed cigarette ligtherplug (female) was on the frontside witch created a massive groud-loop in the unit itself (!), added a dc- filter on the 4mm bananaplug studs inside for extra dc- filtering and changed some component values also witch leaves me now with a 35Amps/13,8VDC small, efficient power supply with almost any noticable RFI by-products. Checked this with a tiny Spectrum Analyser (Aliexpress) and remarkable no excessive heat.
- For backup a President Teddy II little 4 watts AM/FM tranceiver, modified (Jumper re-placed and one cut wire), by the way, a nice little unit and proudly made in the U.S.A.. :)
QTH, Netherlands (Europe)
This should do for now I hope.
Regards.
Reactions: 19wrc333
    boog351 has left the room.
