Yes, but only the 3.3V TTL 3 wire types (RX, TX, GND). Some are 2 wire (multiplexed) and will not work with these radios.
Your cable should look like the one on Simon’s website, and like the pics that Shadetree Mechanic posted…the RXD lead goes into pin 2 of the RJ12 plug, the ground lead into pin 3 and the TXD lead into pin 4. I made that cable some time ago and it works.Can someone please confirm. I got the USB to serial adapter and a RJ12 cable to make the programming cable, what is confusing me is the wiring. The cable shown by Simon built shows TXD and RXD reversed of what the radio RXD TXD is, Is this the way it should be? The TXD for the USB Programmer goes to the RXD connection at the radio , GND-GND, and RXD programmer side to TXD radio connector side?
