Cobra 25 stinger set up
Illahe
New Member
Jun 3, 2026
45
17
8
57
Question: Installing a 1446 stinger pallet in a Cobra 25 chassis that requires 2 w DK. I'm aware of the cap and resistor mod to lower DK. Is there another option that doesn't need heavy mic gain to open up the 4:1. Most of the time they run in the 10W region modulating sans stinger.
Back in the day we advised the drivers that you need variable only if you'll use more than one amplifier. Different amplifiers have different drive requirements. For an over-the-road combo of just one radio and just one amplifier, the resistor mod is simpler, one less knob to turn the wrong way.
Your stinger will probably require around a half Watt to keep it below 10 or 15 coming out. A former employee had a method. He kept the 1-Watt resistor values from 68 to 150 ohms handy, and would use two gator leads. The jumper wire would get cut, and one gator lead to each side of the cut. Trying one then another value resistor would zero in on the desired carrier from the linear. That value got soldered in, and the capacitor added. This is not useful advice unless you have the range of resistor values on hand to try. He got tired of this method and used a 5-Watt wirewound 250-ohm pot on the gator leads. Once the desired carrier level was set, it got unclipped and measured with the ohmmeter. The closest fixed value to that measurement would go into the radio.
Naturally he tried a pot with a smaller Watt rating at first, and it kept wearing out. I explained that if the circuit was using only one quarter of the resistance element inside the control, the Watt rating was a quarter of a Watt, not the full one-Watt rating of the control. We had a 250 ohm 5-Watt pot in our inventory, and it didn't wear out prematurely.
We found it necessary to put a .01uf disc cap to ground from the end of the cut jumper, the rear end that leads to L13, the driver collector coil. Some versions have that capacitor, some don't. If it's there, you don't need to add one.
Have fun and 73
Have fun and 73
I like the schematic that " Uncle Ronnie" posted as well. I get the test procedure you have outlined! saves some trial and error. I have found that the DK on "swing kit" 29's I have done will increase after I tune l14, at times going from 1w to 2.5~. Your method is duly noted.
The thread Ronnie linked also has a board with a high and low adjustment, which I find feasible. Especially if someone get happy with the mic gain.
the "more involved" method is cleaner hands down. If im going for idiot proofing, i build the carrier pot on a trimmer inside the radio for a "set and forget" kind of thing. on a 25 i've also made the ch 9 switch into a hi-low using 2 trimmers inside. theres a ton of options. my 21gtl with a biased FQP13n10 is swingin 15 RMS and 45peak with a clean waveform from a 1.5w DK.
Reactions: Illahe
Respectable performance. Is there a reason you prefer the 13n10 over say Vishay 520.
And did you use a bias potentiometer instead of the "Palomar "bias set op for Mosfet conversion.
i like 520s too, i just saw these on ebay for cheap and experimented. so apparently i got a really good batch lol. i use resistors like 470 and 3.3k with a diode, and 6.8k from the 8v tx line for biasing.
oh and BTW the RFX75 cobra 29 i just un-hacked is now keying 9w, swingin 40 RMS and 90-95ish PEP. i had to reinstall the jumper to the driver stage and make the trace cut but its mean and clean
Reactions: MKwrench and Illahe
Nice!
I just picked up a Connex 33 HP Max, but I don't believe its any louder than a well tuned 29 with "a little help."
do note that if you do decide to run a faceplate carrier pot, you can idiot-proof that with the clean swing mod i posted by messing with the resistors on the hot and ground side of the carrier setting pot to have it max out at like 15w. I make the hot mosfets top out at like 5-6W on a cobra 29's delta tune pot which at around 14-15 RMS at full audio makes big shwing and cooler finals the law
yea, i see thats a biased HG 1446. definetly worth doing the clean swing route and keeping all your power on channel. fear not a proper drilling of the board to route your wires to the solder side, and i usually mount the TIP 142 around the side wall by the audio transformer and 2piecing it with a separate perfboard with a trimmer or 2 ziptied to the wireharness.
I just did this to an old PC66 I'm patching up. I used a 1k pot that I had handy installed on the rear to be externaly adjustable. I ended up going directly to 12v on the hot side and installed a 5k adjustable pot on the ground side to adjust the low side minimum to 1/4W. The max carrier only goes to 3W so I used the PA switch to short the cut trace when it's not pushed and the amp isn't needed, to restore the original 4W carrier. (PA=Power Amp....lol). The OE finals 20W pep doesn't fully drive my DX350, and I remember getting a clean 30+W from a 520 in a simular chassis, but I hate to scrap that OE final (2075 I think)....
I've also tried the diode/cap at the buffer. It makes a cleaner swing than this mod, but is real sensitive to voltage changes in the supply.
