Hi Gang,
I have 2 identical Robyn SB-520's. They both are pulling .4 amps at idle (19 LSB). They are both set at 13.8 VDC. One of the power supply's is running about 30 degrees higher than the other. I am measuring it at the heatsink near the regulator. I measured it with a fluke digital thermometer. You can feel that it is hotter as well.
Any thoughts why?
Thanks as always!!!
Any thoughts why?
Thanks as always!!!
