A quick and simple question
Raccoon
Oct 27, 2005
266
136
53
57
www.youtube.com
In the older Ham radios , is it ok to mix and match you Final tubes . Not the numbers , but the companies . Is it ok to put a GE 6146 tube with an RCA 6146 in the same radio ?
Branding Mixing should be fine as long as they have the same specs and matchup electronically with all appropriate testing.
Reactions: Raccoon
Good chance this will work okay. Bearing in mind that the brand name printed onto a tube only tells you who put it into a retail carton, not necessarily who made the tube. Tubes leave the factory with only the type number printed on them.
Reactions: Raccoon
