Yeah I was thinking about that but was hoping I would be able to get the radio to do it
Simple approach would be a foot switch to key the amp.
As Hookedon6 mentioned, make SURE the amplifier is keyed BEFORE the radio. Doesn't have to be by much; 10ms should be plenty. AL-811s don't generally take too kindly to being hot-keyed.
There's another way this would work, you'd just need to drill a small hole in the back of the radio to accommodate a 1/8" mono jack.
Take a small surface mount relay with a 12VDC coil (Radio Scrap has these in stock) run a wire from the PTT pin on the radio to the anode (non banded end) of a 1N4148 switching diode. Take the cathode of that diode (banded end), and run it to one of the coil leads on the relay. Then run a wire off the other coil lead on the relay and put it to a +12V source in the radio. This will activate the relay when keying the mic.
Run 2 wires off the normally open set of contacts on the relay to a 1/8" mono jack. You can then make a patch cable that has the 1/8" plug on one end, and an RCA plug on the other that will plug into the amp. With this setup, this will allow you to key the amp up when you key the mic. The only thing you'll have to do is find a location for the 1/8" jack.
I do this on all my bases, since I have an AEA LA-30 linear that requires the same type of PTT switching as your AL-811.
Hope this helps, and good luck!
~Cheers~
60 watts drive MAX....on SSB
20 watts drive........... CW/AM
Run the Amp at 500 watts out and she will serve you well
All the Best
BJ
get a relay from mfj,i use the one from them on my ft450d and worked great,ran a fl2100b for yrs...73 Foot switch is good too...
gee,.....you must have gotten a REAL deal on the 811,
FWIW, I would either sell the radio and get a radio with an installed rca jack, designed to carry the 12 VDC (directly to ground) amperage....
or sell the amp and get an RF sensed keyed amp.
just a question,..... does the 811 even have the 10 meter board installed?
In some cases you may want to drive the amp with another radio that would not be modified. Sometimes it makes more sense to install a simple RF sniffer circuit inside the amp to make it key with any radio. You can do this with a TIP-120 Radio Shack transistor and a 1N60 germanium diode across the base and emitter connection (black band on the base).
Ground the emitter. Connect the collector to the center of the existing RCA key line (side of relay coil that needs to be grounded to key). Loosely couple the base to the RF input connector. Do this by wrapping an insulated wire around the wire already connected to the RF input jack. Use just enough wraps to make the amp key at the lowest drive level you will use (3 or 4 wraps should be close).
If you use it on SSB or with reduced carrier on AM you may need to add a small delay. Do this by adding a small electrolytic cap between the collector and ground. The larger the cap, the longer the delay to unkey. I'd start with 100 mfd because this amp does not require a lot of current to key the relay. You do not have to mount the TIP-120 on a heatsink.
PS: If the amp does not have 10 meters, just cut the green wire on the input wafer of the bandswitch.
