AL1200 RECAP: Any opinions on ohmite wirewound resistors for HV bleeders?
357
Walkin' the dog From Chilliwack BC
I Support WorldwideDX.com!
Sep 12, 2009
1,530
916
123
53
Chilliwack, BC
www.youtube.com
I'm recapping my AL1200 and I checked the resistors and they are all 49.xx Kohms and within .5 of an ohm. 2 look like they got a bit hot as the lettering is faded.
I planned on replacing them and since they are wirewound, I got new wirewounds but 10w instead of 7w
I was just wondering before I pull the trigger, does anyone have any bad experiene with ohmite? these are 20J50KE "E" standing for ROHS compliance.
Do you think I'll be ok with these?
thanks
Absolutely nothing wrong with Ohmite. In fact, Ohmite is/was pretty much the industry standard. All the broadcast transmitters I worked on had Ohmite 100K 100 watt wire wound bleeder resistors in the HV power supply section. Globar is another quality name in high power resistors but I have seen them used more in high power dummy loads than power supplies. Globar makes some really good carborundum resistors that are non-inductive and suitable for loads in the HF spectrum.
Reactions: 357
OK thanks.
The reason I'm asking is I tried to put as much research into the parts I could and many suppliers are bone dry for parts and I seen the price go up on what they did have almost daily.
I couldn't find any data on the "crc" resistors that were in there. I did see lots of images of the RCD 170 series and while it was too late because I already ordered the ohmite, the RCD 170 series mentioned low inductance and a main feature which got me worried. data: https://www.rcdcomponents.com/wp-content/uploads/2022/01/100-Series-Datasheet_RevI.pdf
So that got me worried that there must be a reason the went for the inductance feature
Wirewound resistors have one advantage in this application. Their resistance value won't drift with age. A series string of caps like this uses the bleeders to equalize the voltage so it's divided evenly across each capacitor. The inductance they show is not relevant. This is a DC circuit and it just won't care.
Back in the day you would see carbon-composition resistors used for this task. Bad juju. They are famous for changing their internal resistance with age and mileage. But they were the lowest-cost option, and designers would use them with the knowledge the warranty would be long expired before they could cause any mischief.
Carbon-film and metal-film resistors are both perfectly suitable, and likewise don't exhibit a drift problem in my experience. And they're a lot easier to find in high resistance values.
But yeah, I would consider the wirewound part the "premium" option, but not really a whole lot better than the carbon/metal film resistors. Just use one that doesn't run too hot. Heat stress makes more difference than the choice of component type alone.
Reactions: 357
thanks Nomad.
That helps me relax a bit. I am seeing 105C off these resistors with normal use (the ones to the back the fronts are getting more airflow).
Hopefully thats normal. I was hoping 10w would run cool, I guess not
Assuming 400 Volts across each bleeder, this should dump 3.2 Watts in to it. You would think that would keep the temp a bit lower, running at one-third of its rating.
Probably won't hurt anything for the first five or ten years, anyway.
Reactions: 357
No load plate v is around 3600 right? With 8 caps that's 450v each.
With 50k bleeders you should drop each cap to 6.25v or so for a total of 50v across the bank in about 71 seconds. Each resistor will dissipate 4 watts.
A minute is fine. If you could stand to wait two minutes you could use 100k and they will diss 2w .
changing the resistors to 100K 3 Watt Metal Oxide. This was a very bad idea. They should be 50K 7 Watt wire-wound, HV resistors
I seen that online so I stayed with the 50k
I muffed up mounting them a bit close to the board...thats kinda bugging me but I dont see any signs of heat damage yet.
I guess they bleed voltage but they also equalize the voltage across the caps.
