Anderson Power Poles... Where you been all my life?
I hear you. I have used a few of them but really need to convert everything over to them. What did you get for a crimp tool? I have just been using a Panduit multi-purpose crimper tool and dropping a bit of solder on them too. I like soldered connections and find it REALLY REALLY hard to give it up. :wink:
I got one of these. I crimp it flat, then crimp from the sides. I also touch it up with solder. I'd like to have the regular ratcheting crimpers, but didn't want to shell out that much $$$. Not sure, but maybe I can get a die set for my coax crimper.
http://rover.ebay.com/rover/1/711-5...0001&campid=5336136228&icep_item=261233348616
MFJ sells these:
http://www.universal-radio.com/catalog/hamps/3816.html
I'll keep an eye out at hamfests for one. However, these pliers do the job. Soldering them provides additional comfort. I want to make some adapters to series a couple batteries. Definitely going to swap out mobile leads in my car.
My next purchase is a distribution panel.
They are nice, aren't they? I've used them for a year or two, beginning with the crimper you have. I later got the one that's made for them and there's a world of difference. You can't go wrong with that on.
PowerWerx also have multi-connection doohickies, a power distribution type thingy. That is a much nicer way of making multiple connection to something, or a central power source rather than a bunch of pig-tails off of the same terminal(s).
They come in various sizes but I find the 45 amp power-pole connectors will work with almost anything. The last time or two I got the connectors in the hundred count bag, wish I'd gotten two or three bags!
Need a gang of 3, 4, or who knows how many connections all in one 'piece'? Those things can be combined in a number of different ways, top, bottom, and both sides.
You're right! They are really nice...
I just use a Panduit CT-100A crimper like this one. It works great but I should get a better one made specifically for Power=Poles.
I got 15, 30 and 45 amp poles. The 15 amp poles are a little tricky to get just right with the crimpers I have.
I'm quickly realizing that the recommended crimpers are going to be a necessity, especially if you are going to use a bunch of 'em.
I think it would be worth the investment.
Reactions: Slowmover
'Q-tip'? Or maybe toothpick, or just super glue the silly thing! Whatever works. I've also used the commercial thingy that holds two connectors together, or used a zip tie. It's what works. Doesn't have to be pretty...
Power Poles
No need of the roll pins, glue or anything else, they snap together as is. I also don't use solder but can understand a person wanting to.
I've had 4 Ham radios, an Optima & a Hear It speaker equipped w/PP's for close to a year w/absolutely no problems. Like M42, wish I'd started using them long ago!
Geoff S.
That was my point. "What works"
Toothpick for a horse might be big enough.
Lets see... super glue, use once and throw away, but next time its hard to the bottom of the tube.
Commercial thingy... Metal, do I want that coming loose in my power distribution system.
Zip tie... Been there done that until the power taps had the PP spaced nearly next to one another and I had to cut the zip tie.
Person tries to make a constructive addition and you come along with your edgy comments.
'Doc your crap gets old quick...
Don't waste the bandwidth to respond, I'm gone...
Mike, KE5MC
