Another 2517 low receive issue
The picure contradicts what was written in post 45 though. In the post you said pin 10 is closest to the 8v regulator and pin 1 closest to the passthrough regulator, in the picture, it looks like you labeled the pin closest to the 8v regulator as pin1 and the pin closest to the passthrough as pin 10. The picture is the correct way.
Reactions: Hawkeye351
yeah your picture is correct but everything you posted sounds like you lifted pin 10 off the board instead of pin 1.
also, the chip should be installed with the label facing the chassis wall.
any chance it got put in backwards?
Yea, I did lift pin 10. Pin 10 according to the schematic goes through C175 before the speaker if I'm reading the schematic correctly.
Pin 10 lifted:
Pin 10 pad shows 0v
Pin 10 lead (lifted) shows 10v
All other pins still show the same as with pin 10 lead soldered.
Shouldn't pin 10 lead (when lifted) be slightly less than pin 1? If the lifted pin 10 lead shows 10v, then wouldn't that mean the 7222 isn't amplifying?
  • @ Hambones amps:
  • @ ShadowDelaware:
    Hambones the entire amp section would have to be retuned, and the rf transformers re wrapped.
