Any PSK31/PSK63 operators?
Ham Radio Nerd
Apr 14, 2002
9,202
1,686
283
I've been thinking about setting up an interface to the PC to mess with PSK31 & PSK63. Any other digital mode operators here?
</p>
I got a box full of stuff to run all digital modes when I got the TS-850. I've thought about it but I'm so sloooow typing everyone would be QRT before I sent a message.<img src=http://users.joplin.com/dutch64804/posticon22.gif ALT=":22"> Maybe one day I'll hook it all up and give it a try after I upgrade.
<hr />73, Mike
</p>
I have done a little PSK31 and a bit of SSTV and RTTY but not a lot.I use MMSSTV and MMTTY for SSTV and RTTY.I use Digipan for PSK31 and it couldn't be simpler.Amazing what PSK31 can do under weak signal condx.
Garth 9VE01 PE993 CDX993 Learn from others mistakes.You can not live long enough to make them all yourself.</p>
What do you guys use for the interface? I see MFJ has an inexpensive one for under $100. There's a few others like the Rigblaster, but since I don't have any experience with any of them...
</p>
That's it?!?! Are they using CIV for the TX control? I already have an serial interface CIV cable for the Icom...Sounds like I have a new little project...LOL
<img src=http://users.joplin.com/dutch64804/wav.gif ALT=":wav">
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=moleculocdx363>MoleculoCDX363</A> at: 12/3/04 5:02 pm
Well, I picked up a Din 8 connector (for the ACC1 jack on the Icom 746 Pro). and a long audio cable with the mono phone jacks on each end. I cut it in the middle (now I have two cables) and wired it to the Din 8 for send and receive. I put a little 1<img src=http://users.joplin.com/dutch64804/posticon1.gif ALT=":1"> isolation transformer in line by the Din 8 connector on each cable, enclosed in heat shrink. It looks great. I actually did a quick test without the isolation transformer and I had a ground hum on TX, so I quickly soldered it inline to do it right. I did some quick tests and it all works good. The only problem is that Digipan's CI-V support isn't working right for the Icom 746 Pro. Actually, it doesn't work at all <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/mad.gif ALT=">:"> <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/mad.gif ALT=">:"> . I know the CI-V cable works, because other rig control software is fine. So now, I'm going to either find some other software (I wonder if MixW supports CI-V), or rig up another serial circuit.
Oh yeah, of course the first thing I did to test it all out was play music from my computer on the local 11m meter freq. I gotta say, an Icom rig playing music sure did sound nice!! <img src=http://users.joplin.com/dutch64804/yelclap.gif ALT=":yelclap">
</p>
After messing around with MixW2, I finally got it to work with the CI-V cable. It took me hours to get it to work though. I found a little note buried on the web site where I got the cable about it's DTR requirements. Then I had to goof around until I found that it was RTS that made the PTT work. I swear, the documentation on some of this stuff is almost non-existent. Anyway, it all works great now. I can do all the digital modes with MixW as well as control the rig. Making the cables cost me maybe $20 for parts (if that...less without the transformers), and the CI-V cable was about $20. I guess I could've made the CI-V cable, but it really only would've saved a couple bucks. Still is a whole lot cheaper than the commercial ones.
</p>
