Anytone 6666 and Lincolin 2. Whic would be better
They both sound great on SSB. I was impressed with frequency stability and audio quality. I don't do AM so I can't help there.
Reactions: 357magnum
The President has a 2 year warranty that can be extended to 5 if you buy their antenna. Does the Anytone even have a warranty? I have heard excellent things about both radios although I don't own either one. I was looking at these a while back and then came across a good deal on a Stryker 955.
Here is an excellent review on the Lincoln:
http://www.cbradiomagazine.com/Radi... II/President Lincoln II CB Radio Export.html
http://www.cbradiomagazine.com/Radio Reviews/President Lincoln II/President Lincoln II CB Radio Export.html
Yes that is one drawback to the anytone, no US support as far as warranty. There are a couple of sellers I've seen that warranty themselves but I don't know about all that. I've owned one for quite sometime and the other for a couple of months with no issues but I can only speak for myself. Like you said, decisions decisions!
Well Thanks a lot all ! I never considered the Stryker until these posts , Talk about decision's ? $ wise it's right in the Ball Park & if spec's are close a little more wattage than you can get from an At-6666 .:confused::eek::whistle:
Reactions: TheRATT
Bobby , Not lying just checked the Stryker out this Am . I must say pretty impressive ! How close to do you get to the spec wattage output ? I already have a Stryker antenna so.... ?:LOL:
Lincoln II over the Anytone - just better build quality, even in the plastic on the front. They both are good radios but 10 years from know I'd bet the Lincoln will still be working and the Anytone will be in the trash based on the quality.
Stryker works fine but definitely isn't a nice compact radio like the Lincoln and I like the frequency adjustment way better on the Lincoln for freeband and 10 meter.
