Doesn't work on mine. Figures.Got a 3 watt dead key,swings to a whole 6 with mod. pot turned up.If its a best smart cb the itty bitty bugger you push the second button from right or channel selector and hold the mics ptt then turn it on .will show ph or pl.tap the up or down button on mic n select ph shut off n start it again.letter H should show about middle of righ side of screen.if not try again.and on some just push thatbsecond button n turn on,select ph via mic up down button n see if H shows up
which mod did yours have?if you unsoldered op1 only its a 40 channel only cb.if you unsoldered op1 and bridged solder op2 its got like 7 bands.Doesn't work on mine. Figures.Got a 3 watt dead key,swings to a whole 6 with mod. pot turned up.
If 40 channel only it wont go to high power.i had 2 of them and thats what i
That was it,problem solved. Thank you!
Just the right size for these newer vehicles that don't have any room for a full size radio.For what they are they are decent.only reason i traded mine off i prefer ssb.they were traded for a ssb radio.otherwise stout little buggers in a pint size package
anytone smart cb.about the size of 2 cassette tape coversWhat model radio is this thread referring to? Both the Anytone 5555, and 6666 have SSB.
The Smart. If you had a battery pack you could put this in your coat pocket and an antenna on your hat.What model radio is this thread referring to? Both the Anytone 5555, and 6666 have SSB.
