Bed Mount, but where?
CyberRider
Aug 21, 2018
47
41
18
41
Hi - I got a 94 Toyota 4x4 and I've decided that I want to mount my new 5' Firestik on the bedrail somewhere. For sake of best send/receive where on the bedrail should I mount it?
Oh, and I'm new to this WHOLE cb thing. Bought radio but haven't installed it yet. Never had a cb before at all.
Welcome to WWDX, for best send and receive it would need to be in the center of the roof. If you must do bed rail then the back corner by the tailgate would be the spot. Unfortunately where most people put them is not the best place.
Chris
Reactions: The DB
Firstly, what type of antenna do you have? I am a fan of magmounts.
This on the roof of my S-10 Turbo 4.3 Vortec and it will never blow over.
Mounting on the bedrail is .... well .... ok - I guess.
Where? You did ask, and unfortunately - on the Bedrail - no "real good location" can exist.
Can you invest into a headache rack? At least you'd have height...?
Is there a knockout plug on the tube itself - for wiring? Because that's chrome - and if needed - use a bar between the lights to handle the antenna - it's better because you gonna' strike stuff like trees, overhangs, small critters and the occasional bald eagle whipping around in the air. So let it take it out on the bar brace for the antenna not the roll bar with the lights.
So let the lights offer the mount for the antenna bracing - that's the best spot that won't tear a hole in the truck...
Reactions: 357magnum
OK, I may be willing. But which mount will work for that?
You would have to have a tab welded to the light bar. After seeing the rear window in the cab, I would get a magmount. Antenna would be at the best location and after seeing the gear in the bed you do some serious off roading and a magmount can be taken down and put up in a hurry if you need to talk to others on your trek.
No it won’t. I run a tri-mag on my dump truck. It works great until the cups those magnets sit in start rusting. Then it comes off the top, you run it over and this me attached pic is what you get. Pretty strong antenna, the Predator, 29,500 pounds ran it over and it still looks that “good”.
What kind of trails do you usually run?
If you deal with a lot of overhead obstructions it may not be a bad idea to go with the bed mount and accept the loss in efficiency, an antenna in a less than optimal location will probably work better than a broken one. Of course if you're usually in the desert this most likely won't be a problem.
If I was going to put it on the roll bar I would probably agree with Andy and mount a separate bar running between the light mounts, make the bar a little weaker than the light mounts so it gives if you whack something really hard.
I had a Toyota FJ 40 once as much as I hated to I drilled holes and mounted a 102" whip on the rear drivers side , I rolled that thing twice and the antenna stayed in check . Mine was a 102' stainless . Boy was I ruff on a vehicle !:ROFLMAO:
Reactions: Robb
After all this back-and-forth I'm thinking of just going with a good stud mount on the bed rail just behind the passenger side. I'll probably deal with the inefficiency of the antenna. That's a stake hole mount and I got no stake holes in my bed.
Usually hills. And there's plenty of trees.
...use a bar between the lights to handle the antenna...
Nah. Frankly, I don't have the time, know-how, or money for that.
I can't weld and I don't want to pay someone else to weld it. So that's out.
No mounted antenna on top of the cab. In my opinion that looks ridiculous (ie hick, hillbilly, etc).
...and after seeing the gear in the bed you do some serious off roading...
I'd say semi-serious. I mainly climb hills. But in the wet season I could get stuck. And I don't wanna be up-the-hill without a shovel and jack and other emergency items.
