Cereal motors and parallel universes part deux
kopcicle
Sr. Member
Feb 17, 2016
2,232
3,699
273
Motors in series have full amperage, but half voltage.
Motors in parallel have full voltage, but half amperage.
So, if you had a 110V 500A system:
Each motor in series would see (a maximum of) 500A @ 55V.
Each motor in parallel would see (a maximum of) 250A @ 110V.
With DC motors, they create "Back EMF", essentially a voltage that has to be overcome, proportional to their RPM.
So, you start off in series, so you get maximum power (Amperage), and ramp up until the current you are putting in meets the back EMF.
Then you switch to parallel, so you can continue accelerating, albeit not quite so strongly (Higher voltage overcomes the back EMF, but the halved amperage means you don't accelerate so quickly).
You would thus end up with a torque curve something like this:
Code:
|            |                        ___________|
|            |                    ___/           |
|            |                ___/               |
|<- Series ->|            ___/                   |
|            |        ___/                       |
|            |    ___/                           |
R            |___/                               |
P          __/                                   |
M        _/  |                                   |
|      _/    |                                   |
|    _/      |<----------- Parallel ------------>|
|  _/        |                                   |
+----------------------TIME------------------------
While the power seen by the motor (This is for one motor) looks like this:
Code:
|----500A----,
|            '--------------AMPS-------------250A-
|            ,==============VOLTS============110v=
|====55v====='
Without switching, the graph speed/time graph would look like this (with switching shown in [dotted line):
Code:
R             ____________________________________
P          __/
M        _/
|      _/
|    _/
|  _/
[code/]
So the question is...
How?
Dramatis personata:
[URL]https://www.diodes.com/assets/Datasheets/DSS2540M.pdf[/URL]
[URL]https://viitorsemi.com/wp-content/uploads/VTM606C700LSA_datasheet.pdf[/URL]
[URL]https://diotec.com/request/datasheet/sk34sma-3g.pdf[/URL]
[URL]https://precisionminidrives.com/product/16mm-length-double-head-12v-mini-coreless-dc-motor-8mm-dia-model-nfp-d0816[/URL]
Act one:
[ATTACH type="full"]76047[/ATTACH][ATTACH type="full" size="800x549"]76047[/ATTACH]
And this takes us to the (silk) screen play
[ATTACH type="full"]76048[/ATTACH][ATTACH type="full" size="776x627"]76048[/ATTACH]
Let the games begin!
Are you sure about that? What did I miss? Since when did more voltage mean less current draw? That only applies if you wish power consumption to remain constant but that does not happen in a simple fixed resistance case.
...Yeah, I'm sure. That's my test rig. ;-)
I have seen big three phase motors (100hp+) that switch from Y to Delta as they wind up. Used simple timer modules to switch big contactors.
My kids power wheels jeep had a setup like that. Series for slow and parallel for fast.
When I put a 12v battery in it, I wired them in parallel controlled by a toggle switch on the on/off pedal....
Reactions: kopcicle
We used to run some big liquid separators, Westfalla Decanters at the processing plant.
Same, big 3 phase 480 v 125 HP that switched from Y to Delta windings, same setup.
Massive stainless steel rotating assembly.
Complementary Power MOSFET, (Dual), 60/-60V, 15/-10A, 30/70mΩ, Automotive Grade.
At least that's what the brag sheet says. 15A on the Nmos side, 10A on the Pmos side @ 60V.
900 WATTS
I guess it's the minimal on state resistance...
  • @ heartbreaker3473:
