Cobra 1000 GTL Alignment Procedures?
this chassis is based on the 29GTL board and that board is the precursor to the 29LTD that we all know well.
you should be able to use that alignment procedure as the boards are pretty much the same.
double check before you make an adjustment because there could be some part number differences.
here is a link to that alignment procedure: http://www.cbtricks.com/radios/cobr...st/graphics/29ltd-st_29wx-st_sm_pg12_pg34.pdf
remember that there is a mistake in the other "factory service manual" link on the cbtricks 29ltd page, and it contains the procedure for the 25 instead of the 29.
the one i linked you to should work.
Thank you I will look at that tomorrow
