Cobra 29 LTD Classic Schottky Diode Mod
Is Schottky Receive Mod Worth Doing?
  • Yes it Makes a Noticable Difference.
    Votes: 5 23.8%
  • Maybe, it Depends.
    Votes: 9 42.9%
  • No Not Worth Doing
    Votes: 7 33.3%
  • Total voters
    21
Shadetree Mechanic
Delaware Base Station 808
I Support WorldwideDX.com!
Oct 23, 2017
7,720
13,896
798
53
The First State (Delaware)
Hey guys,
I have a Cobra 29 that I am going to use in my garage station and will be using it with an amp so I plan on lowering the dead key. I figured while I am in there, I could do the Schottky diode receive mod.
So my question is: Is this mod worth doing on this radio and would I notice a difference?
Any thoughts and replies welcome.
Thanks, 73s
Yeah, sure - why not?
Schottky diodes are diodes that are really fast at switching on/off with a low threshold turn on voltage. IOW, when they do switch on/off, they do it with accuracy and are sensitive. Not as sensitive as the germanium diodes turn on voltage they replace, but pretty close. This keeps extra low voltage noise out of the receive, and allow the noise blanker circuit becomes more stable/accurate. They are usually put in both the receive and noise blanker circuits.
I've seen a few radios where somebody had put a bunch of Schottky in other circuits. Didn't see any harm done, AFAIK. Dunno if it really helped - either
(prolly gonna catch h*ll here too for this but here goes...)
Greetings!
Well, if the radio is quite old, more than 10 years, then those diodes may to be swapped out. Age, surges, vibration and static can affect the diodes crystalline structure and create punctures in the barrier or can induce a reverse-bias performance hit in the PN junction of the older diode that can add noise and distortion effect in both the DC and AC realm that many young people can hear as "shot noise" or a rattle in the speaker - so if you have that issue with the 29 now, recapping and diode swaps are prolly needed...
To use Schottky? I always get a kick out of the Wiki definition calls the "Cats whisker" a primitive Schottky Diode ... considering the era - there was a lot of hard work done during those earlier times...
If your 29' uses the TA7222P audio amp versus the 5-pin 1022 - then Schottky is a personal choice, yes they are silicon, and they removed 1/2 the junction issues so they have a lower forward voltage drop - but the later-year (2007/2008 and later) models already use derivatives of the Schottky in the 1N4148.
The earlier year models used the Germanium type but just some specific areas. Othrwise they used 1N4148 / 1N914 types which were high-speed switch types for ANL and NB - but they too were less "purified" than the Schottky has in it's pellet today...again as technology went ahead, the older analog designs get left behind.
If you decide to use Schottky - you miss out on the performance curve the Germanium types provided the receiver in both detection and in AGC response.
The earlier 29's were designed with older, slower - less sharp diodes and had a receiver quality unlike that which is hard to duplicate in todays slilica-based radios today. The best way to put it would be the RIAA - warmth in bass and low-tone clarity that many older enthusiasts enjoy versus the crispy, nearly snappy sound of silicon based. SMD types you are seeing more and more of. - the not-so-sharp rounding of the audio detected out of a Gemanium Detector can still be discerned by many radio listeners.
The older 29's compensated for that. The newer ones just added tonal caps to offset the crispy nearly krinkly sound of potato and Dorito chips versus the more milder deep fryer Mickey-D's fries. The capacitance they use to get the spectral roll-off generates a hit, or loss of signal, that many want back in their radios - so they try schottky and it does bring back the predictable performance the older 29's have - you still have the losses incurred by the engineering of the tonal filters used in the audio chain - you don't get the audible warmth the older 29's responded to when it came to audio punch...
So look over the radio and decide, Schottky can help with noise floor and an overall rebuild of the Diodes used in the RX strip in the older chassis can always be a benefit - but it's splitting hairs. Older radio Germanium and Silicon is different than todays replacements and you'll notice the difference.
I am seeing a resurgence (SIC) in people wanting more of an Analog-era feel and Germanium is leading the way in many of the audio tracks musicians are doing these days. The amplifier Fuzz effect in original germanium based "pedals" is noticeably different than their silicon counterparts - even when they use the schottky low-voltage junction drop diodes to replace the originals.
In a way, you are doing that same thing...requesting advice on how to get a 29's receiver back to a time - when they were known more for their reproduction of audio from the carrier that used Germanium than in the skew and slew improvements in distortion, noise floor and recovery rates the silicon types present versus using the older signal diodes.
Just wanted to help remind us all of the time radios were the #1 means of communication.
Regards!
:+> Andy <+:
Greetings!
Ok Part II
Here are some Travel Lodge Postcards to help you find those special spots along the way...
These Photos from the Brochure, CHAPTER XXIII - The Diode's Way...
This one is for the Receivers L9 and Noise Blanker - out of a Cobra 29 KEPC - 225C about 2007' Vintage (ST)
And here is the next one on page 3 - SWR and Means To You...
Hope the above help you in making a decision on choosing the right part to replace those older weakened parts...
Regards!
:+> Andy <+:
Greetings!
Ok Part II
Regards!
:+> Andy <+:
The radio is only a couple of years old at the most. So the Schottky diodes won't help because it already has Germanium diodes? Just making sure I got this right.
Greetings!
No , er well - if you want to replace their diodes with Di-Lithium Crystals or even the more refined Folgers' Models ..... We'll see if they can wake up that radio...
I'd prefer Dark Roast myself...
Seriously_Mode=On...
Sorry had to re-set a flag - Saturdays around here get a little crazy...
They, more than likely, use Schottky based 1N4148's - which although may sound like were violating a law in IEEE or ISO - they're really not ,due to their proposed purpose.
So (scenario) say the "factory" that makes most of the Semiconductors used in the Cobra 29 are from Factory "X" - and they produce Schottky types for general commercial use and Cobras' get these 1N4148 made to a Schottky standard - doesn't mean they are Schottkys' just produced used materials dies and process that are also the same for Schottky. (Like Ford Sources to Mexico, but that doesn't mean it goes great with Lime Juice or a free 6-pack of Corona is included - it's just that you get an instruction manual that can teach you how to identify the vehicles parts in Spanish - translated to English - and the real meaning behind why "Open Other End" is printed/embossed on the BOTTOM glass on the bottle of Cronoa...)
Just so you know, Schottkys are a major standard manufacturing process now so you'd be hard pressed to find mainstream parts with Germanium as a main ingredient. OR to locate a factory that still makes PN junctions to older standards...(hint: Pb-free)
Which then would indicate that Cobra 29s' are SOURCED from Factories that may not make, use or develop Germanium type of Semiconductors - which than means that Cobra / Dynascan has to re-outsource to locate the detector diodes to meet a specific standard.
But do they?
I've got LX and LEs laying over that are all 1N4148 derivatives - meaning not one of the diodes' have a voltage drop below 0.4V - which is typical of Schottky being silicon - Germanium ones from the 2007ST (Shown earlier) are 0.3V or so voltage drop.
You are not guaranteed the same level of quality or performance EVEN THOUGH THEY ARE ENCAPSULTED TO APPEAR AS SUCH - does not mean that the IEEE standards are violated, just they are low-power capacity capable and the Glass enclosure is merely for outline and packaging purposes as Small Signal Diodes. IT does not mean they are REQUIRED to be germanium in there - just they meet a spec that makes them suitable for it and Cobras' Management says - go ahead...
I've got 687 and 787 from Uniden that are all SMD and all are Schottky derived.
As technology goes ahead - we may find ourselves more and more disadvantaged when it comes to enjoying the sounds the older chassis provided.
So enjoy and keep, respect and cherish, revere and remember - these old radios are classics and may never come back.
Regards!
:+> Andy <+:
HI...the issue with this mod is the front end semiconductor (which this isn't an IF stage) will have a story commotion improvement of .3 to 1db which is simply not worth the exertion, in the event that you do some test with RF signal generator which will go down to .2uv and up to 100mv and utilize a SINAD you will see that I am correct. The most ideal route is to attempt and improvement the powerful reach is to take a stab at changing the AGC assault, have you at any point had a go at catching the AGC yet cautious doing this as you can blow the front end semiconductor up. A few radios I have accomplished for my self have customizable AGC.
Glad somebody is paying attention...
https://www.worldwidedx.com/threads/mike-debunks-shottky-diode-receive-mod.236937/
https://www.worldwidedx.com/threads...-schottky-diode-swap.23680/page-9#post-328902
https://www.worldwidedx.com/threads/magnum-s3-schottky-and-2n2999-mod.254483/#post-718345
If you NEED to have to fix the diodes in the radio, then SALVAGE as many Germaniums as possible that check good enough to be re-used - and use those in the IF's AUDIO PATH (Can't stress this enough- AUDIO - not AGC).
I DO NOT recommend the Schottky types as a replacement for the Detector section, for they are silicon (Si) based, simple SINGLE junction weld pellets - use them in the AGC lines.
I realize that not everyone is able to rebuild radios using their OEM parts, they simply are not around anymore.​
How good will Schottky work? Depends on the ALLOY metal they weld that pellet to.
You can't do anything about their "shot noise" - Germanium has an inherited High-Frequency Roll-off curve that makes it appealing to reduce this effect.
IF you play with RX Sensitivity to Noise level - try Schottky in the AGC section.
If you want better RX audio, use GERMANIUM (Ge) type in the DETECTOR and thru the audio PATH - including Noise Blanker, if necessary, to reveal a better response curve time lag - frequency dependent - noise spike reduction process.
  • Not ALL Noise Blanker's use 27MHz, they may peak their coils at 23MHz to even as low as 16MHz (Imaging IF) so the "harmonic" you're dealing with in impulse noise may not be at the same frequency that the NB strip is tuned for.
Good luck!
So I assume we want 27MHz as noise blanker. What is simplest method to determine this?
I do have the Cobra 29 NW LTD Classic, 2020 edition.
I also have a supply of NOS ITT 1N40/1N34 1N60 germaniums
plus many pounds of NOS Ti 1N4148s from early 1980s.
I think these were the last of the Ti Made devices for when
they were doing down hole oil and gas drilling electronics.
I'm currently evaluating performance and want to enhance my CB.
I'm going through researching how to make my radio better.
One of the few things I don't have is FFT rig that goes into the RF range.
I only have AF range to about 100kHz.
So is there a simple method to scale 27 MHz to the 100kHz range and look
at it through simple Audio FFT?
Reactions: Slowmover
First: Welcome to the WWDX forum!
Second:, Ah, huh?
Swapping diodes around really won't make a difference you can measure.
And "better" is not very specific. If you want it to do something differently than it does now, okay. But consider that the performance of the radio's receiver is typically limited by the level of noise that comes down the coax from the antenna. The radio's internal noise is almost never the limiting factor to what you can hear.
What kinda specific "better" do you want to achieve?
Any kind of design starts with a specification of some kind, even if it's a broad one.
Dirt cheap Software Defined Radio (SDR) is a reality. https://www.rtl-sdr.com/about-rtl-sdr/
IF you're asking about the Noise Blanker coils' own frequency - it should use a NON-resonate spectrum in which to detect noise, otherwise the peaking of the section before and the section after - the birdie generated at specific frequencies will generate a "on" signal that will kill all RF passing the output of the Noise blanker.
The Process of using the Noise blanker is to obtain a noise from a range of spectrum close if not in the range of frequencies you're trying to quench the noise from (if the non-resonance can be obtained)
You can try the 16MHz range - but the effort may not work for it SHARES the same the PLL will put out - hence a birdie, the On signal and killed RF Strip.
Cobra and Uniden did a little trick to a peaking coil by changing a cap in the 16MHz Peaking coil used in their FET 1st IF front end (LA181) - and renumbered it(LA180). They used a larger value cap LOWERING the Resonance frequency to about 13MHz to 16MHz (tune range) in the NB strip. (You can use the OPPOSITE IMAGE - for the detection - just don't go tuning for carrier - the cap value used is keeping you away from that)
In using a Heterodyne principle, you have a mixing product in two regions - ABOVE and BELOW - the NB peaking coil is designed to use the OPPOSITE image of the Heterodyne that is passed into the 1ST IF..
That's the problem - too far out of band, you don't get much outside impulse noise to work with that passes into the strip except the internal birdie and whatever is in the image.
Then you have the bandwidth product of trying to locate and shunt the impulse and yet discern that from the Audio embedded in with it.
Many radio manufacturers have abandoned the older "amplify and shunt" and go with more of the ANL Clip and limit/hold the filter used in it - provides.
They call it DSP - I call it junk.
Ok, understand that you are several decades into Schottky and revisions to BOTH ANL and NB sections in both Detection and Semiconductors used - you don't have the luxury of the discrete 380/495's and 1815/733's of older generations.
  • These older unit had an Hfe gain factor and bandwidth product that makes the higher frequency roll off - and the subsequent frequency response to that upper limit - more of a challenge so they worked with values to force the clip and limit/shunting - they HAVE NOT changed those values since - so that means the faster response of the newer dies of the parts subbed into the strip they use now - is way higher and those values have not changed to follow their new performance curve.
I Did not know that - I learn something new every day.:)
One thing though, and you may find yourself in a spot having to abandon the project due to it's effects.
  • - because you cannot find a Diode in Schottky that will LESSEN noise - it may do the opposite - RAISE the noise - but not by what you think.
  • The Diodes of old were "slower" and were more intrinsically exhibited a filter-dependent characteristic. They were not of pure Germanium - more like it's ore Galena in a crystalline Salt form. (Cats whisker) so they exhibited a reactive element...
Some feel it's similar to this...
But, were dealing with Frequency Response.
This puts it as more of a pass filter network
The above is If you were to examine a Diode as it's Electrical Characteristic ...
Physically they are different too...
To see the 27MHz effect, - er, no - not readily - but thru the use of Heterodyne (Image) you can place audio into a carrier and see the effects of bandwidth performance thru the NB on and NB off and review the results by simply producing a carrier and inject audio either as white noise or tones you pick - to see their output on a monitor radio or thru the receiver of your DUT. (Device Under Test)
Understand too, that as you work into this, your best friend is your DVM.
At least, in using it's "Diode" setting - for as your work with Schottky and Germanium versus Silicon or even Selenium - you will find that their performance in specific areas are different (Audio reproduction is one effect) and that forces you into a redesign of the output network filter to obtain the best results from the OEM versus Revised.
So when you use your DVM, note the "Diode Drop" values - you'll find some of the best Audio Detection is thru Germanium using a 0.23 to as high as 0.47 (Diode Forward Voltage Drop) but Schottky will be more in line with Silicon as 0.45 to as high as 0.82 - rivaling Si with Selenium being more like 1.40 or even higher.
Germanium Diodes, as they age, give higher DFVD (Diode Forward Voltage Drop) as their junction bond degrades from vibration, ages and power spikes. You may encounter this but too, note the "sound quality" from the detector and audio reproduction - as you make these changes you may find restoring the OEM parts may be a better fit for the radio then to try and force upon it any sort of upgrade.
Same of Selenium types of rectifiers - worse of the Contenders.
Si and Schottky are similar with Schottky having the lower end of the drop but remember too - the "recombinant" region (P to N - Intrinsic) is non-existent - so you cannot "filter" the noise present from the rush of electrons trying to cross the barrier (roaring of a wave so to speak) and some recombine with the Holes in the Positive layer - you lose some of that information during the recombine as the older PN barrier designs do. Due to that Schottky thinner layer, the Electrons take the energy around them present at the time - which may or may not contain the audio information - just the energy level from the "Bounce" - they pass this information thru (over) the threshold) barrier and out the conductor - it doesn't mean it's the "Right" information - just information.
So in my experiences with PN devices, the Holes the Electrons tend to carry into - work as part of this intrinsic audio filter effects (With Schottky you can experience or hear a snapping or crispy/near crunchy sound effect compared to Germanium) many experience when they swap out the different diodes and observe the effects in the noise level and in how the AGC will work in regards to the newer changes.
Why the discrepancy? Do your search finding EQUVALENT performance parts as you post your results - it is best if they can be duplicated by others.
