DX350 oscillation issue
MKwrench
Wooohoooo!!!
Aug 6, 2023
138
131
53
55
I grabbed a used DX350 and Black Widow DX250 to fiddle around with They both look nice and clean inside and appear to be all original, except for the DX250 having 2879s in it. I rigged up my test equipment as a station monitor switchable between the antenna and test load.
On a dummy load they both look great and show impressive (to me) numbers on my meters.
I adjust the deadkey to 50w for testing the 250 on high where it swings close to 300w PEP.
Then the 350 with a 65w carrier will swing to over 350w PEP.
My antenna is an attic dipole with a 1:1 feedpoint choke and great match across the 11m band. When I switch to the antenna vs the dummy load I get a strange oscillation that I found gets better when the carrier is raised on the 350 or the channel frequency is raised on the 250.
The 1st video is the 350 acting up on the "AM in" setting on the antenna. The 2nd is High on a dummy load. A few more pictures show AMP voltage, Radio voltage and the extra CM choke I rigged up directly behind the amp, and my attic dipole measurments.
I read somewhere that the metalized mica caps can drift causing issues, coud this be whats up here? What do you think?
  • A.Low DX350.mp4
    280.6 MB
  • D.High DX350.mp4
    90.3 MB
Don't remember seeing the metal-clad mica caps go bad. Does make me suspect either a loose circuit-board screw or missing/ damaged negative-feedback resistor/capacitor issue. I have seen the capacitor on the secondary of the input transformer go bad and create issues. Worth checking.
Reactions: MKwrench
I'm glad you responded, I'm a little more confident about getting in there and checking things out. I'll start with the feedback sets as recommended.
I'm really not familiar with the insides of these yet.
Why does that balun look like it is at the radio end instead of at the dipole? The balun needs to be at the antenna's feed point, not at the radio.
Add a common mode choke at the feedpoint, maybe more than the toroid too. Wind some coax coils if you can.
A 1:1 SWR does not mean the parasitic oscillation (different frequency) sees a 1:1 SWR. If improving the common-mode rejection does not improve things, change coax length to hopefully make the antenna system not support the self-oscillation frequency.
Reactions: MKwrench
The antenna has one at the feed point already, I just added that other one to see if it changed anything. I agree that it's going to be the antenna causing the issue, I'm finding out that the further I go into the 10m band from 11m the better that carrier behaves.
The feed point balun is a mix 43 240 core, dual bifilar wound with 14ga speaker wire 6 wraps per side, the new one I just put together (is behind the radio now) uses Teflon wire instead, I was going to swap it out tomorrow. The radials on the dipole itself are 12 gauge solid core insulated wire from some leftover Romex I had laying around.
Okay I think We got it, My feed line is two sections of LSR240 (supposedly equivlent to LMR240), One 50' run from my attic feedpoint balun down to the basement, and anorher 20' or so from that point to the transceivers. Its where I had them connected that caused my problems.
I didn't have a "barrel" connector or a SO end to fit the 240 line, but I did have an old TVI trap to use in place of a "barrel" with two PLs. I thought it was a convenient way to kill 2 birds with one stone and mounted it to the basement rafters (or floor joist... whatever).
Just now, I removed the balun/choke from behind the amp, the little antenna that was fine gets the fuuzzieness now too. Then, I removed the TVI trap in the dipole line and the issue dissapeared.....
Now I see the issue closer to the top of band 5 on the Stryker. I'll deal with that crap another day, It still works nice up there on SSB, so I can still yap in the 28s.
Cool, I'm glad I dont need to repair anything in the amp, I'll work on the aesthetics instead.
But, stay tuned I havn't tried the 250 again yet,....
