Echo board for my Magnum S-980
radioman24
449
34
38
I'm needing a echo board for my Magnum S-980. Who has one I can buy??
The echo board in that radio is a custom item found only in a Magnum radio from that era. It has both the echo and talkback on it. That board was never imported as a sale item separate from the radio, far as I know.
Just looked at the Copper web site. Every echo board there is marked "discontinued".
If you install a typical aftermarket echo board found on Ebay you will lose your talkback feature.
It’s possible Avera Distributing may have one. It’s also very possible that I have one laying around here somewhere, I’ll look.
Whats wrong with yours?
Also, Nomad is exactly right. That board has a relay that clicks on when you key the radio, that’s for the talkback. Either repair your board or replace it with exactly the same type made for a Magnum.
It has a issue that it's making the radio key up and stay stuck in transmit when you turn it on. When I bypass it radio works fine.
Dan
