I have heard Mark on the airwaves talk about using 1/2 wavelengths of coax to tune antennas. This also goes along with the common CB shop belief all coax cables must be in 3 ft. Increments.
So if I have a 1/2 way dipole antenna cut for 40 meters. The minimum ideal height above ground would be 66 ft. which is a half wave at that frequency. That means according to Mark, if use more than 66 ft. (1/2 wavelength)of coax up the tower, My antenna won't tune properly unless I put my radio directly at the base of the tower because I can't use any more to coax get inside my shack which would be at least another 25 ft.
Then again 11 meters has it's own theory that doesn't apply to Amatuer bands. CaptainKilowatt taught us that.
