I don't know jack about that amp, but as far as looks, I think it's coolThanks Andy, super interesting info. I always try to post up when I run across something different like this as inevitably someone else will have questions on another one in the future.
I did a google yesterday and very little came up for "568BLYCF" but I found this link - https://archive.org/stream/73-magazine-1980-01/01_January_1980_djvu.txt
When I searched the text on the page I found the text below which is why I mentioned 454.
MRF454/568BLYCF
17.10
150ma
30MHz
2/$ 1.00
I guess we can assume the transistors are from late 70's/early 80's which would match the wood grain on the face of
To give you some idea of age, the relay has a date code on it from 1975. The fact that it is still working 45 years later, does say something about it.
I guess we can assume the transistors are from late 70's/early 80's which would match the wood grain on the face of the amp
Potter and Brumfield made the best relays. Many amp builders used the R10 like in this photo. The R50 flatpack (the white square rec amp relay) were prone to failure because the contacts shifted when they were soldered into the board. The date on the relay doesn't really reveal the amp build date, just when the relay was manufactured and put into stock. Those R10 relays rarely ever go bad.To give you some idea of age, the relay has a date code on it from 1975. The fact that it is still working 45 years later, does say something about it.
