Help with Uniden Grant XL
crappykraco
Aug 6, 2014
120
51
38
I have a Grant XL purchased on ebay. When I got it it would power up, receive just fine, but no TX light change. I found cracked solder joints on all three legs of the final and repaired. Did a shotgun replacement of all electrolytic caps (it had black YEC for the most part), and got TX back.
Grant XL into a watt meter and dummy load yields the following:
AM mode channel 1: 1/2 watt DK swings to 4 watts
AM mode channel 20: 1/2 watt DK swings to 4+ watts
AM mode channel 40: 1/2 watt DK swings to 3 watts
LSB channel 1: 5 watts
LSB channel 20: 6 watts
LSB channel 40: 3 watts
So uneven and lower than expected TX power. I've included a picture. I see one coil is missing its wax and has been adjusted and it looks like a couple wires used to be soldered to the back of audio transformer.
I am an electronics novice at best, but have some basic test equipment and can solder.
I have a multimeter, BK 1040, a freq counter and an old hitachi scope but I'm 95% clueless when it comes to using it.
I hope to be able to return this radio to normal operation with help from the kind folks here.
Do you have an alignment tool with the proper 1.5 mm tip on it? The old G-C number for that one was 9440. They show up on fleabay. Just don't try to use a metal screwdriver to adjust the small tuning cores. The entire problem may be alignment. The black ferrite cores (slugs) are brittle. If you crack one, that can be a headache.
Do you have a dummy load and source of an audio tone? My preferred way to peak the adjustments in the transmit chain is on SSB with a steady tone into the mike, turned down under a Watt. This makes peak settings easier to observe.
Not much point to digging deeper until you're sure it's aligned for max power.
i am using these instructions.. not sure if 100% the same. My radio has PB-208AD
Nomad: Yes i do have an assortment of plastic tuning tools and have one that fits. I have a BK1040 so that is my watt meter, dummy load, and audio source for 1hkz tone.
On CH 19 USB used BK1040 to inject 1khz tone into the microphone. Adjusted L47,L48,L46,L45, L38.
I saw a positive result right away, the smallest adjustment to L47 and the radio pegged the 10 watt scale. Went through the rest and this was the best I was able to achieve.. more like it I think. VR11 seems to work, but feels awful to turn and creaks and groans.
When checking the driver and final bias I am not able to get a reading above 18.5ma.. Unsure if I may be doing something incorrectly. I'm pulling the wire from tp 8 and inserting my black probe into that pulled wire, and putting red probe on the TP, key mic and adjust vr9 looking for 25ma. Similar procedure for the final. I see 18.5ma in both places and no matter what i do to VR8 or VR9 i see no change.
I'm sorry if my questions are silly! I wish I had someone local to sit down with and learn from.
When the alignment procedure says "input of oscilloscope to TP2, adjust for maximum" what exactly does it mean? adjust for maximum what? I don't know what I'm looking for on the scope.
Counter hooked to TP3, I was able to get the USB and AM adjusted to 34.985, and 34.9815. Attempted to adjust L22 for 34.9885 in LSB but couldn't quite get there with the clarifier knob in the middle. i can get to 34.9874 with l22 turned what seems like its max adjustment.
Maximum voltage. Maybe the clarifier has been modified?
34.9815 and 34.9885? A 3.5kHz SSB offset? Shouldn't it be 1.5kHz in this radio? Never even seen more than 2.5kHz, so 3.5kHz stands out as odd to me.
I am not familiar with the grant xl...
edit:
I've always seen the VCO offset match the LO offset, and RadioMods shows a 1.5kHz offset for the last LO (7.7985 and 7.8015). I am therefore led to believe that the VCO frequencies should be 34.9835 and 34.9865. Hopefully someone can sanity check that for us.
I abandoned the direct counter measurement of the vco output long ago. Once the three 7.8 MHz carrier frequencies are right, I tune in the signal generator with 1 kHz modulation, and a tone box with a 1 kHz crystal-controlled tone. When a sideband receiver is fine-tuned correctly, the pitch of the modulated tone will be identical to what you hear switching to AM. The tone box lets me hear an audible beat between the receiver's speaker audio and the tone box audio. This gets USB and LSB within a couple of Hertz without having to wait for the 1-second update period of a frequency counter. This only works if both sources of 1 kHz audio are accurate. AM mode is less fussy, and gets set on transmit with an external counter inline with the dummy load.
Faster is better when you do this a lot.
This is interesting because i have been doing the same thing in a slightly different way for a long time now.
I set the VCO 34mhz cans with the freq counter to be dead nuts on.
Then i set the AM 27mhz signal to be dead nuts on with the AM IF can.
then i use the sig gen which has been calibrated for 1khz exactly and "beat tune" the sideband IF cans so the tones match when switching from AM to each sideband.
once this is done i check the output on my known good ham radio and the voice on SSB sounds very full and on freq.
nomad can you tell me why you choose to set the IF and then tune the VCO using this method?
If i can improve my methods im all ears.
Thanks for this idea... I used bk1040 to inject 1khz tone into the mic. Listening with headphones on a radio i know is dead nuts on (ftdx10), at a volume level where i can still hear the 1khz tone in the room coming from the BK.
I know this isn't exactly the procedure you described, nomad, but it was as close as i could get with what i have.
This is almost a "musical" way of tuning and got the radio sounding good on channel 20 SSB. I work on musical instruments for a living so this was just like tuning a guitar to me. It still sounds garbled or something on channel 40 and lower power output.
Scraped the wax off of l19 and learned enough on my old scope to follow these instructions:
2. Set Channel Selector to 40CH Adjust oscilloscope to DC range and connect "+" Probe to TP1 and "-" to L22 Jumper. Adjust L19 so that voltage of TP1 becomes 3.5V. Moreover, check when adjustment is completed, change Channel Selector to 1CH and the voltage of TP1 should be 2V or more.
After completing the above change back Channel Selector to 19CH.
3.Connect Oscilloscope to TP2 and adjust L21 to its peak.
4. Connect Oscilloscope to TP3 and adjust L20 to its peak
Now... the radio no longer sounds garbled or distorted on any channel.. but i still get lower power output on the higher channels. This is where i actually use the darn thing, so i hope to be able to sort it out.
If it is only low on the higher channels, is that to assume you have full power now on the low channels? Was the low bias issue resolved?
Low on the high channels is almost certainly a TX can misaligned somewhere, likely at the TX mixer.
crappykraco,
just so you know you can use a regular DMM to set the VCO.
the others do require a scope.
as for the TX power, you need to do a TX alignment.
set the radio for channel 20. AM mode, mic gain down.
key the mic and set L48 and L47 for max deadkey.
do the same for L45 and L46.
now turn the mic gain up and inject a 1khz tone into the mic.
if you don't have a tone generator you can find a youtube video playing this tone and just use your phone held up to your mic.
now adjust L38 (the big plastic one near the final, NOT the one near the antenna jack) for max modulated wattage.
now turn the mic gain back down, and note your deadkey on channel 20.
go to channel 40 and adjust L46 to even out the deadkey with what it was on 20.
now go to channel 1 and adjust L45 to even out the deadkey with what it was on 20.
jump back and forth between these two adjustments on 1 and 40 until you have the same deadkey across the 40 channels.
Thanks for the help Brandon and LC.
Well now i really did it. At one point i got a 3 watt DK with the mic gain fully down, and when attemping to peak L46 on ch 20 the needle dropped to zero in an instant. I tried to put it back and nothing. Started from the beginning and wasn't able to achieve any better than 1.5w DK. On top of that the core of L38 came loose from the threaded part of the coil and I haven't been able to get it out yet. it looked wobbly or crooked when turning, but i didn't realize it could fall down in there.
