Help with Uniden Grant XL
crappykraco
Aug 6, 2014
111
51
38
I have a Grant XL purchased on ebay. When I got it it would power up, receive just fine, but no TX light change. I found cracked solder joints on all three legs of the final and repaired. Did a shotgun replacement of all electrolytic caps (it had black YEC for the most part), and got TX back.
Grant XL into a watt meter and dummy load yields the following:
AM mode channel 1: 1/2 watt DK swings to 4 watts
AM mode channel 20: 1/2 watt DK swings to 4+ watts
AM mode channel 40: 1/2 watt DK swings to 3 watts
LSB channel 1: 5 watts
LSB channel 20: 6 watts
LSB channel 40: 3 watts
So uneven and lower than expected TX power. I've included a picture. I see one coil is missing its wax and has been adjusted and it looks like a couple wires used to be soldered to the back of audio transformer.
I am an electronics novice at best, but have some basic test equipment and can solder.
I have a multimeter, BK 1040, a freq counter and an old hitachi scope but I'm 95% clueless when it comes to using it.
I hope to be able to return this radio to normal operation with help from the kind folks here.
Do you have an alignment tool with the proper 1.5 mm tip on it? The old G-C number for that one was 9440. They show up on fleabay. Just don't try to use a metal screwdriver to adjust the small tuning cores. The entire problem may be alignment. The black ferrite cores (slugs) are brittle. If you crack one, that can be a headache.
Do you have a dummy load and source of an audio tone? My preferred way to peak the adjustments in the transmit chain is on SSB with a steady tone into the mike, turned down under a Watt. This makes peak settings easier to observe.
Not much point to digging deeper until you're sure it's aligned for max power.
