For 6 metres, the East coast Canada way.
The thought did occur to me to try and extend it to 6m but the complexities of the tank circuit as well as the fact I have a solid state 1.2 Kw amp for that band brought my to my senses.
Right church wrong pew.
It's a home built HF amp for 1.8-30 MHz. continuous. It will use a 3CX3000A7 ceramic tube which will eat a Maco-750 for breakfast and still be hungry.The tube has a plate dissipation of 4000 watts and a grid dissipation of 225 watts making it almost impervious to over driving with a 100 watt exciter as well as tuning errors. Power supply will make 4500 volts for the high voltage supply.
And I thought you were adventurous...The thought did occur to me to try and extend it to 6m but the complexities of the tank circuit as well as the fact I have a solid state 1.2 Kw amp for that band brought my to my senses.![]()
Well sometimes I do have to balance adventurousness with sanity. Sometimes sanity wins and sometimes it doesn't.![]()
<sigh> yet not enough for ch 6 . . . lulz . . .Oh crap......this means I may have to upgrade some pieces of feedline eventually when things are done. Not sure I want to trust foam dielectric RG-8. It's only rated for 300 volts and that's only 1800 watts. My legal limit is 2250 pep or a full 750 watt carrier on AM plus 100% modulation for a peak power of 3000 watts on AM mode.![]()
