A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
Remove r417 and check q404 output voltage again. If still 0.8V than transistor is not working.
If voltage raise, it seems to be shortcut on r417 0v side.
Mike
Hello, I disconnected the connection in between Q404 and R417. The result is: that the side of the transistor now voltage is 3.1V instead of 0,8V. I checked R417 which is similar to R415 and give the same Ohm measure. On the other hand even is voltage passes thrue R415, that line should have 5R9V.Regards
Mike
