I have an Eagle 500 on the bench that someone TRIED to repair; it ended up being pulled from one shop and given to me.
The main Antenna switch relay has problems, it has burned the printed circuit board from under it.
Can someone with a working Eagle provide me with a picture of the PCB that the relays are mounted on, I am going to hard wire in relay in after I clean up the burned out area.
